Question about Hitachi 60EX01B 60" Rear Projection Television
Main factory color settings
Need to re-adjust the main color settings on the t.v.
  • 1,476 Answers
You haven't supplied enough information to adequately address your problem. Color drives are not adjustable by the consumer and it would be risky for an inexperienced individual to attempt it. I may be able to provide more advice if you can supply a better description of your problem.
Posted on Jun 22, 2006
Why is color poor?
Try a factory reset [hard reset] to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 10, 2016 | Sanyo DP50747 50 in. Plasma TV
How can i perform factory settings on my Sony TV model KV-29LS0B. i want to reduce the RED color in the factory and increase Green color in the factory sittings.
Oct 01, 2015 | Sony Televison & Video
Geek Squad broke my Television
Try these settings:
Picture Mode: Movie
Contrast: 100
Brightness: 44
Sharpness: 20
Color: 50
Tint: 50
Backlight: 7
Color Tone Warm1
Digital NR Auto
Detailed Settings
Black Adjust Low
Dynamic Contrast Low
Gamma -1
Color Space Auto
Edge Enhancement On
xvYCC Off
White Balance
R-Offset 21
G-Offset 20
B-Offset 21
R-Gain 0
G-Gain 21
B-Gain 26
My Color Control
Pink 20
Green 15
Blue 15
White 15
Auto Motion Plus 120hz: Low
Feb 28, 2014 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
JVC AV-27S33 only displays black and white (Color gone) Menus are still in color!
Check its color system adjustments. It will be best to make a factory reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it after 10 minutes of so. This must make your TV a hard reset. If this do not help you, the chroma section circuits of your TV need to be checked for fault/s. This is a skilled work, and it will be best to contact any experienced service technician.
Jul 04, 2012 | JVC AV-27S33 27" TV
Wires got cut from factory harness to the factory stereo need to figure out wire color codes
http://www.the12volt.com/installbay/stereodetail/347.html
Should be it.
Sep 24, 2011 | 1998 Buick LeSabre
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
My camera lost it's color ability. Is in black
first lets try to isolate if its a camera setting issue, try initializing the camera back to factory setting (home>settings>main settings>main settings 1>initialize). the camera should return back to its default settings.color mode should revert back to normal. if images appear washed out in the sun, try to minimize this by using the lens hood. if it doesnt help try adjusting the EV (exposure value). if still it doesnt work, possible underlying hardware issue, cam may need repair. but hope this helps.tnx:)
Jul 21, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Color printing
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Projection t.v.
When you say Main color setting, Do you mean your trying to make the colors look better as there are no main color settings but there are main screen controls and this would give the set its B & W settings so then the colors look better. And theres main focus control that would sharpen up the picture. Ok first thing your gonna need to do is Get a service manual so we can find where all the adjustments are. You should ba able to find a service manual if you look in your user manual for a service station for hitachi. Now if your a tech or experienced with tv repair we can go over this but I need to know exactly you are trying to do first Thanks
May 28, 2006 | Hitachi 60EX01B 60" Rear Projection...
Hitachi 60EX01B 60" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
