Question about Hitachi 60EX01B 60" Rear Projection Television
Projection t.v. need to re-adjust the main color settings on the t.v.
  • william fox May 30, 2006
    techman, its a westcoast tv and the main foucus, color settings need readjusted with no matrix
  • 3,130 Answers
When you say Main color setting, Do you mean your trying to make the colors look better as there are no main color settings but there are main screen controls and this would give the set its B & W settings so then the colors look better. And theres main focus control that would sharpen up the picture. Ok first thing your gonna need to do is Get a service manual so we can find where all the adjustments are. You should ba able to find a service manual if you look in your user manual for a service station for hitachi. Now if your a tech or experienced with tv repair we can go over this but I need to know exactly you are trying to do first Thanks
Posted on May 28, 2006
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
How to adjust the color on my 60 inch philips tv
color is adjusted in the main menu; do you have some issue or problem with the set?
Mar 17, 2012 | Philips Televison & Video
The color is messed up. the color is all different colors like red,green and blue.
Your convergence is out of whack.
This can be caused by a failed convergence IC - or can be adjusted using the Convergence settings in the main menu.
May 15, 2011 | Toshiba 55H70 55" Rear Projection...
Blue, red and green are separated and i cannot find convergence from main menu
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from
Sep 22, 2010 | RCA P52939 52" Rear Projection Television
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Blue Convergence
go to main menu , selet advance setting , after that there is another menu where u going to find a convergence ajustment , select convergence adjustment , than choise blue , than after u access to blue color press the audio boton to do the blue , if u can't muve the blue color u going to have a repair service maybe ur stk or convergence ic are bad
Jan 06, 2009 | Mitsubishi WS-55513 55" Rear Projection...
some of the tvs eliminate this option if the settings are on "auto color " or something similar depending on the brand; if that it doesn't fix it we will need more info.
Dec 02, 2008 | Televison & Video
Main color
The Matrix?? Color converters. Ok Lets assume you mean the screen controls that adjust each color of the Picture tubes?? No you can not. Oh maybe your taking about the convergence? Its only necassary to adjust the lines on the GRID or CROSSHATCH if they are drifting and out of alighnment. You certainly can, if your tweeking the controls all the time, wear them out but that would take alot of tweeking. If your set needs tweeking all the time then there is a problem in the convergence and should be addressed asap or the problem will get worse. ou should never go into a set as theres high voltage even when the set is unplugged for a while and will hurt you bad. Always seek a pro in case you need any internal alighments or tweeking. Good Luck
Jun 09, 2006 | Hitachi 60EX01B 60" Rear Projection...
Main factory color settings
You haven't supplied enough information to adequately address your problem. Color drives are not adjustable by the consumer and it would be risky for an inexperienced individual to attempt it. I may be able to provide more advice if you can supply a better description of your problem.
May 28, 2006 | Hitachi 60EX01B 60" Rear Projection...
Hitachi 60EX01B 60" Rear Projection Television Logo
125 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
