Question about Fuji FinePix F480 Digital Camera
Lens covers wont close!
My fuji f480 is having trouble closing one of the little flaps that closes to protect the lens when the camera is off. Its so frusterating!!
    Novelist:
  • 111 Answers
Seems like you have a problem with the lens cover mechanisms within the camera, this could have happened for many reasons, such as dust, knocking the camera, or just wear and tear. if the camera is still within Fuji warranty i would advise you to not attempt to fix the problem your self.
I would suggest you call up the Fuji Customer services or visit their website to see if the problem can be corrected with a repair/replacement of your current camera
hope this helps !
Posted on Oct 28, 2008
Cant get battery compartment open
Sorry just got this message okay here is a sequence for opening, closing and removing the battery.
I'm also supplying some diagrams. The battery compartment is a push type towards the outer edge of the camera body then it swings up and open.
Battery cover picture
Loading the battery
Removing the battery there is a little catch on the one corner that needs to be released.
Have fun with your camera
Dec 27, 2010 | Fuji FinePix F480 Digital Camera
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
Lens cover stuck
im having the same prob with mine right now. my little sister had it for a while and she said it started doin it ramdomly but now the lens wont close at all
Nov 04, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Sep 13, 2008 | Fuji FinePix F10 Digital Camera
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 | Cameras
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover issue
Check the Fuji Web site - but I fear it will be new camera time when you see the repair price
Aug 03, 2007 | Fuji FinePix F10 Digital Camera
SAND IN MY SONY DSC W50 CYBER-SHOT CAMERA
Hi there, this job is for a pro. Please do not try to open the lens. However there is a way and I will help you. Please contact me at live session. Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Lens cover sticks closed.
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Sep 30, 2006 | Fuji FinePix A303 Digital Camera
Fuji FinePix F480 Digital Camera Logo
100 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
