Question about Danby DWM5500W Front Load Washer
Danby DWM5500W Washer
The machine will not use cold water for any cycle. The water is hot for all cycles, even the rinse cycle.
I had it also, Swap your hoses. I had my hot and cold on wrong.
Posted on Feb 07, 2009
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
When turned to "cold" the
Rinse is always cold only on most machines. Why? Because rinse with hot water causes wrinkles. You have a bad cold water solenoid or fouled cold water valve innards from lime and such OR a clogged water valve inlet screen on the cold water side. Remove the cold water hose and check for blocked screen.
May 03, 2011 | Washing Machines
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Rinse cycle and cold/cold temp are not working
You either have a faulty cold water inlet valve or you have the cold water hose connected to the hot water inlet valve. Cheers
May 15, 2009 | GE Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Hot water on cold water wash or rinse
hmmm..now that's really interesting..that's a function of the control board..methinks you have an error in the panel and control center.
Mar 09, 2008 | Kenmore 44072 Front Load Washer
Danby DWM5500W Front Load Washer Logo
113 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
