Question about Maytag Kitchen Ranges
F2 alarms keeps coming on. - Maytag Kitchen Ranges
  • 725 Answers
F2 is a runaway temp code relay or touch pad are stuck... need to replace touch pad and relay board... I have heard that some cleaners will get into touchpad and cause this error..
Posted on Sep 13, 2008
I'm not even using my oven and the F2 alarm keeps sounding every minutes. What is wrong?
First, check the oven sensor and see if it reads 1080 ohms @ 77 degrees F or close to that at room temp. Post back your results.
Nov 18, 2012 | Hotpoint RGB745 Gas Kitchen Range
Cannot start even charger is already pluged
restart computer keep pushing f2 f2 f2 f2 sec. screen pops up change your boot for f12 f10 exsept the boot format then restart push f12 go to sec. optsion then it will ask to run windows click on that then see if your windows will come up.
Feb 05, 2011 | HP Pavilion dv6000z Notebook
The oven keeps blinking F2 what does that mean
F2 Heating mode high temperature This alarm is activated when the ERC senses a runaway heat condition or when the temperature exceeds "runaway limits". The ERC will beep until the cancel or another function is selected. If the alarm repeats the F2 code check the oven sensor and wiring after first checking for a stuck relay. If alarm goes away verify the oven will complete a clean cycle without any type of failure.
Nov 25, 2010 | Dacor Ovens
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Nov 20, 2010 | Magic Chef Kitchen Ranges
My pc alarm keeps going off when i switch on
You need to log into the bios to disable that feature by pressing F2 at system boot up. If you need further assistance, you can give us a call at 800-595-3564 24 hours a day, 7 days a week.
Jan 17, 2010 | Computers & Internet
F2 is flashing and alarm is going off!
This is what the code means.
F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
press the clear button for 10 sec. to try to stop it.
Good Luck and Please rate Fixya!
Dec 29, 2008 | GE Profile 30" Self-Cleaning Freestanding...
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
F2 error code
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
Apr 18, 2008 | Dryers
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
77 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
