Question about Lexmark X2500 All-In-One Printer
Lexmark 2500 Series printer does not work properly.
The printer first worked very well. Now I get printer error messages. The test page prints OK, but the paper feeder light blinks. I can't print other jobs, however. When I try to print anyway, the printer makes a loud clunking sound. Can anyone help? Lynn
  • zinny89 Sep 23, 2008
    my printer used to print well. It has ink and everything. Now it wont print documents but it will still print the test page. Whats wrong?
  • Anonymous Dec 18, 2008
    My Lexmark printer will not load and has a flashing light . What is wrong
My lexmark 2500 series prints and copies fine, but will not scan pictures to my computer.
Posted on Feb 09, 2009
My printer does not print, but tells me i have prints pending
Posted on Sep 17, 2008
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
Lexmark x544 108.02 printhead error
1. Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return?
Yes: Continue to Step 2.No: Print a test page. If the page prints, the printer is working correctly.
If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.Did the error message return?
Yes: Contact Lexmark @ 1-800-(539-6275) No: Print a test page. If the page prints, the printer is functioning correctly.
Aug 16, 2011 | Lexmark X544n All-In-One Laser Printer
My Lexmark printer is showing 122.03 service fusher error what can i do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
Contacting Lexmark
Please contact Lexmark Technical Support for additional assistance.
Jun 10, 2011 | Lexmark X543dn Laser Color All-In-One...
What does 900 Service RIP Software error message mean and how do i reslove it
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
I installed new cartridges in my X2550 Lexmark I want to print a test page. It scanned the test page but will not print it. What do I do?
it depends on the error message why the test page won't print. If it just won't print at all, try to reseat the paper into the printer and turn off/on the printer then try to print the test page.
If it doesnt, then turn off the printer, remove cables. And then press and hold the power button on the printer for 5 seconds . Reinsert cables and turn on the printer and print the test page anew....
Jun 04, 2010 | Lexmark X2550 All-In-One Printer
My Lexmark x125 all in one only prints blank pages
configure the proper port for the printer if you using usb cable for printer select the usb port in the properties of the printer ......
check the port you configure to printer
Oct 06, 2009 | Office Equipment & Supplies
2500 Lexmark won't scna
print an alignment page and scan that page.
it would work.
Jun 24, 2009 | Lexmark All-in-One Printer with PictBridge
Cant get my lexmark 4270 series going on my computer help
Go to Control Panel -> Printers. Is the printer listed here? Is the printer Online (It will say Online or Offline next to the printer tile)? If it says Offline, the computer cannot currently see the printer so check to make sure it is plugged in and turned on and that the cable is connected from the computer to the printer. If it is Online, right-click on the printer tile and select Properties. On the General tab, click on the Print Test Page button. After a few moments, the printer should spit out a test page. If this prints out, your printer is working properly. If not, let me know what error messages (if any) it displays or the overall printer behavior (blinking lights, beeps or other noises, etc).
Apr 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
433 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
