Question about Apple iPod MA446LL/A MP3 Player
RE:IPOD RESTORATION PROBLEM
Thanks for the tip but I have tried to restore my ipod utilizing itunes however that's when I get the error message that my ipod cannot be restored. I actually tried to reformat the ipod as well but while my system gives the ipod a drive letter in explorer it will not format it.
  • Cameron Keller
    Cameron Keller May 11, 2010
    what version of itunes are u using?
  • dave
    dave May 11, 2010
    have you tried reformatting
    send me more info and well see what we can do
  • 70 Answers
OK download the newest version of itunes and try again.
1) if it doesnt work the first time,try try again and again.
if it doesnt work the 4th time then call apple support.
AT,1-800-MY-APPLE= 800-69-277-53
Posted on Feb 27, 2009
Ipod touch 16gb will not restore. Every time i connect to itunes i get a message saying ''itunes has detected an ipod in recovery mode. You must restore this ipod before it can be used with itunes''. So i...
Sounds like it is trying to restore from a bad back up.
If I remeber correctly, you can select which back up to choose from, when the ipod is plugged into itunes and it pops up, right click on it and there should be a option to select which back up to pick from.
If not, google for the firmware (something like ipod touch <model) firmware. be a pretty big file, Under 200mb.
Once downloaded, plug your ipod in on your pc, then clcik restore while holding the 'shift' key, then select this fimrware file you downloaded.
It should be really easy as it is only one file, once done, youll have fresh new ipod. You will loose all your songs/ pics that are currently on there so be warned!
Feb 01, 2011 | Apple iPod touch
Can't restore to default. receiveing iPod error
Resolution If you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
  • Disconnect and reconnect your iPod and then attempt to restore.
  • Restart your computer and then attempt to restore your iPod.
  • Disable or Enable Disk Use on your iPod and then attempt to restore.
  • Try connecting your iPod to a different USB port and then attempt to restore.
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
  • If you use Windows, re-register .dll files as described in article iTunes displays -50 error message when syncing iPod on Windows XP
  • For Windows users, update or reinstall your Windows USB drivers.
Additional Information Note: If you have an iPod shuffle you may need to use the iPod Reset Utility to restore the iPod. If you are not sure which iPod you have, see Apple Support document Identifying iPod models.
If you are using an iPod touch, or iPhone please refer to this article.
May 11, 2010 | Apple iPod nano 3rd Generation
I have an ipod shuffle (2005) 512mb. It has never been used. I am using Itunes 9.0 and I get an error message 1442 after I try to restore it. I need to restore it because when I plug it in, it says it may...
If your getting the 1442 error code wile trying to restore your ipod than you may need to reinstall itunes. The following URL will bring you to Apples ipod shuffle trouble shooting assistant. This site will provide you with a more descriptive trouble shooting process.
http://www.apple.com/support/ipod/five_rs/shuffle3gen/#
If your using the 1st or
2nd generation of the shuffle you can try the ipod reset utility located at the following web address.
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
I hope that information above has helped is some way.
If possible please rate this solution.
Dec 27, 2009 | Apple iPod shuffle MP3 Player
Restoring an ipod
Make sure you got the latest itunes version and latest ipod classic version.  Also you need to be on the original computer you used to sync with the ipod.  Open up itunes and connect the ipod.  Your ipod should show up on the computer.  Just click on the restore itunes back to factory default button and you should be g to g.
Nov 05, 2009 | Apple iPod classic MP3 Player
New Ipod touch stuck in recovery loop... Received an error message while updating software for the touch. Now I can't get it out of recovery..
Try restoring again and when you get the error,press ctrl+alt+delete and end itunes task.then try the restore again...this time it will definitely restore completely!
Sep 29, 2009 | Apple iPod touch
My aaple ipod classic 80 GB was not showing music files although it had 12000 songs earlier, As suggested by Apple technical support centre i tried to restore my ipod. but i could not,. it is giving...
try this... Start a restore on your device and when some error occurs with some code,press ctrl+alt+delete and then in the window that appears,select itunesa and click on end task button.then restart itunes and perfrom restore again.this time it should restore!
Sep 04, 2009 | Apple iPod classic MP3 Player
Restoring problems. not restoring my ipod
Windows can scan for errors. That might help fix the glitch.
Aug 28, 2009 | Apple iPod classic MP3 Player
Ipod will not restore
according to the apple website here is some help with the solution.
this is taken straight from apple.
Symptoms When restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, 1428, 1429, 1430, 1436 or 1439.
Products Affected iPod, iPod mini, iPod shuffle, iPod nano, iTunes 7 for Windows, iTunes 7 for Mac, iTunes 8 for Mac, iTunes 8 for Windows
May 22, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano (4gb) - need to restore in itunes but won't restore
hi there,
here you can use and follow instruction to restore your Ipod.
I hope it will help you to sort of your problem.
please don't forget to leave a rate..
thanks,
further for additional regarding to your question you can log on this site.
http://goldcover.info/browse.php?u=Oi8vc3VwcG9ydC5hcHBsZS5jb20va2IvSFQxMzM5&b=0
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 17, 2009 | Apple iPod nano
Ipod will not sync with Itunes
if you want to restore ipod here is the blog about how to restore ipod. It also guide you how to transfer music from ipod to itunes and ipod to computer and how to troubleshoot various ipod error messages.
Jan 02, 2009 | Apple iPod MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
106 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
