Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Propane consumption what would be the maximum propane consumption be for a 24 hour period in gallons of propane.
  • 1,420 Answers
1/3rd of a gallon per hour on high. It will not run on high all the time. .3X24=7.2 gallons worst case.
Posted on Sep 15, 2008
Superflue. Why doesn't it stay lit?
If this is in a RV there is a propane monitoring valve. It will close and cut of the propane if it is not being used for a period of time or if there is a leak. The valve is mounted between the propane tank and the first appliance, usually inside the RV.
Mar 09, 2016 | Water Water Heaters
How many gallons of propane will I use per month?
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
Mar 06, 2017 | Heating & Cooling
I have a new Hayward H400FD ! How much Propane does it need in one hour of heating ??
A 100k btus burns roughly 1 gallon of propane per hour. A400k btu heater burns approximately 4 gallons (actual is somewhere between 4 - 4.18 gallons per hour.) That's assuming that the heateris running non stop during this time period.
I know your question was fairly simple and disp notrequire a whole lot of information but we appreciate you giving us somefeedback!
The Ugly Pool Guy
www.WeFixUglyPools.com
Dec 11, 2010 | Hayward H Series Pool & Spa Heater 400k...
Dear sir i have a empire/corcho 1500 btu heater and i have a 70 gallon tank of propane tank but the heater says natural gas can i do this or do i have to use a conversion kit and do i do that and where do...
First off, yes you can convert it to propane. The difference is that the orifice, which should be in the conversion kit, has a smaller hole for the gas to pass through and needs to be changed. Secondly, the air consumption on propane is greater than that of natural gas and for that reason you need to open the air venturi, usually to the max to allow the largest amount of air to enter. Don't overlook the pilot light as well, it also needs to have a different orifice installed. You can find new orifices and/or conversion kits at the store where you buy your propane, assuming it's not a big box retailer. Go to a local propane supply location for the parts. Another option is to go directly to the manufacturers home page and order the propane orifices.
Oct 04, 2010 | Reddy Heater RLP100 Portable Forced Air...
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
Natural gas consumption chart 4 1m gas power generator waukesha
NG consumption will be specific to the generator itself. Your best bet would be to consult the user manual, or at the very least, post the model #.
A very loose rule of thumb is that if your generator consumes 1 gallon of fuel at a certain load, it will consume 100CCF (aka 1 Therm) of NG, or 1 gallon of propane.
The numbers that you are stating are WAY above Stanly power generators, are in a class that is considered to be Commerical Equipment.
Jun 21, 2010 | Stanley Electrical Supplies
Can i hook two 500 gallon propane tanks together instead of purchasing a 1000 gallon tank?
yes you can but please get a propane gas certified engineer to do it , its really a job to be done by experts , the explosive power of propane is just to dangerous to mess with
Nov 10, 2009 | All-Pro Propane Garage Shop Heaters - All...
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
Mr. heater problems
defective venturi or cob webs in burner
Jan 17, 2009 | Mr. Heater Mr Heater Portable Buddy...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
87 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
