Question about LG Washing Machines
My tromm washer is kicking up code dE - LG Washing Machines
  • 706 Answers
A DE code means: Door not all the way closed, Loose electrical connection at the Door switch or circuit board that monitors it or the door switch assembly is damaged
Posted on Sep 14, 2008
Cracked plastic window in front loader washer
Stop Kicking Your Washer!!! First! The glass is a material Hybrid from the NASA Apollo Space Program! That was Some Kick! Can't buy Just the Laminar Plastic Piece. You have to purchase THE ENTIRE DOOR dummy! Go to Sears.com, They will Love your Money and deliver via Space Shuttle Free...LOL
Oct 13, 2013 | LG WM2688HWM TROMM SteamWasher
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
My LG TROMM washer is giving me an error code dE what does it mean?
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 01, 2011 | Washing Machines
My LG washer TROMM displays the code FE what does that mean?
Overflow error.
Water level frequency is over 213
If FE is displayed the drain pump will kick in to prevent flooding.
Might be a bad water valve OR it could be a clogged water pressure tubing (from tub to control)
Your tech service manual and some notes are HERE
Oct 19, 2010 | LG WM1812C Front Load Washer
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
http://www.howtomendit.com/answers.php?id=28214
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
164 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
