Question about Cameras
Panasonic Video will not turn on
The camera will not turn on. I have charged the batteries and still the
camera will not power up when I turn it on.
I have 3 different batteries and it will not turn on with any of them
    Genius:
  • 3,422 Answers
HI,
I suggest you to switch to a 2500 mAh Nickel Metal Hydride rechargeable batteries first.
Posted on Sep 13, 2008
  • Cameras Master
  • 19,396 Answers
Check the battery contacts, if you see fluid or oxyde on battery contacts that can be the cause.
Test if the camera starts with a charger, if it has the socket, if it does not even start with the charger then camera is faulty.
In this case take it to a camera repair shop.
How do charge the camera
you do not charge the camera !
You have to charge the removable battery in the charging dock.
it is then placed on the charging dock that is plugged into the power outlet.
The battery needs to be slided in the direction of the arrow on the charging dock.
The battery is located in the camera at the back near the bottom of the camera.
http://www.nodevice.com/download/user_manual/panasonic+nv-vz1.html
Jun 27, 2015 | Panasonic Video Cameras
HDC-SD1 No Power
Battery could be discharging or worse, power transfer within can is broken
Jul 21, 2014 | Panasonic HDC-SD1 Camcorder
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
Panasonic HM-TA1 won't power on with battery fully charged.
The battery will not charge when the device is turned on. Make sure that when you connect it to your computer via its usb that you do not turn it on otherwise it wont charge.
The annoying thing about this device is that when you connect it to your computer and turn it on, on the LCD it will say "connecting via usb" and the memory bar will show that it is fully charged, however the battery is not. This must just be a design flaw as the battery won't be charged.
Just remember to plug it in and leave it, do not turn it on!
Jan 24, 2011 | Panasonic HMTA1 Camcorder
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Panasonic PV-GS39 will not turn on
I have the same problem.  Did you find a solution?
May 04, 2009 | Panasonic PV-GS39 Mini DV Digital...
There is a flashing red and then shut down NV-DS65
battery is not charged or is defectived. or the power supply is not working.
i suggest replacing the battery or getting a new power cord
Apr 23, 2009 | Panasonic NV-DS65 Mini DV Digital...
Panasonic DVD Palmcorder (VDR-D100) 1.5 yrs old will not power up
Nope men... I have Just the same problem... I have a VDR-D105 and suddenly doesn't turn on... i was recording with a full charged battery and suddenly just turn off... forever :S
Jun 04, 2008 | Panasonic VDR-D100 DVD Camcorder
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
