Question about Nikon COOLPIX S10 Digital Camera
Lens error When I turned on the camera it had on the screen Lens error and was vibrating when it turned on. The only way I could shut off the camera was to take out the battery. After a few hours, the camera is now working. But, I do not want this to happen again. Why did I get that error?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
My camera is displaying error 0000018-4489-957-000, what i do ?
The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
Mar 14, 2011 | HP Photosmart R727 Digital Camera
When I turn on the camera, Lens error shows up on
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix S210 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Screen says LENS ERROR
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2009 | Pentax Optio E60 Digital Camera
It has a lens error. Everytime the camera is turned on it beeps and clicks constantly. It eventually shuts off after displaying "Lens error, restart camera." on the screen.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 23, 2009 | Canon PowerShot SD1100 IS Digital Camera
Nikon Coolpix S10 Problem: Lens Error The camera is less than a year old and "Lens Error" has suddenly appeared on the LCD screen. The camera makes a vibrating noise when it turns on then...
You can take pictures ( without VR function ) by starting your camera from play button then switch to photo !
Lens error appear after a shock . VR mechanism have piezo actuators glued with epoxy resin together with an carbon fiber stick . After a shock applied this epoxy broke so no vibration from piezo is transmitted to slider . It is possible to repair ( cheap , only epoxy and izopropilic alcohol needed ) but skills are necessary
(i am not an english speaker so ....)
Jun 28, 2008 | Cameras
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Nikon COOLPIX S10 Digital Camera Logo
23 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
