Question about Maytag MAV6200 Top Load Washer
Clothes will not wring out water
When washing towels, water is not completely wrung out of the towels. They are still too damp..I have replaced belt, took off drain hoses and checked for clogging. Could Ii get some suggestions?
  • Anonymous Mar 16, 2014
    need to get door open to get towels out, it also just hummed like it trying to pump water.
    President:
  • 878 Answers
On this model, first check your pump for proper operation. Wet clothes can be the result of slow spin speed, which can be casued by a binding tub seal or bearing, brake rotor assy. not disengaging properly, or a slipping clutch spring. You also want to check to see if you have anything binding between the tub and basket that will slow it down. Sometimes a sock or lint can wad up and cause a drag.
Posted on May 28, 2006
Makes grinding sound when agitating & when spins clothes must be wrung to get more water out
Your pump is going out. I have seen em lock slap up in one direction only and not leak but the bearing be gone. Easy fix. 3 s/8th inch screws hold the pump to the base. a couple screws hold the service panel on and you need pliers to get the hose clamps loose. The belt comes off easy by hand no tools need. The belt also might need to be changed which is simple. Let me see if i can find a video.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 15, 2013 | Maytag HAV2360A Top Load Washer
Hi - My Whirlpool washer appears to not use enough water. Don't get me wrong, I want the machine to use low water (that's why I bought a front loader, model: WFW97HEX). However, when I stop the...
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
Aug 30, 2011 | Whirlpool WFW97HEX Washer
What do i clean the screen with?
Cleaning is simple. Vacuum the rear vents to remove any dust that has built up.
For screen and the fascia, -
1. Unplug the monitor from the power supply.
2. Fill a bowl with warm water with some washing up liquid - just as you would to clean dirty dishes. Soak a soft clean cloth in the water (Kitchen cloth - NONE ABRASIVE!! and not a sponge!), and wring the cloth out so that it is damp (not wet!) and gently wash the screen. When finished use kitchen roll to dry off the monitor.
3. Stubborn marks on the LCD, using the same damp cloth, apply a spot of neat washing up liquid to the cloth. Clean as before - DO NOT PRESS on screen. When finished, use kitchen roll as before.
Voila!
May 14, 2010 | Acer 22" X223w LCD Monitor
Getting the machine to spin heavy load
you have a bad belt, your drain is too high
you can change the belt but you may need to get a high velocity pump if your drain tube is much higher than 1 foot above the machine
Oct 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
Olympus 795 sw lens moisture
Exterior:
• Wipe gently with a soft cloth. If the camera is very dirty, soak the cloth in mild soapy water and wring well.
Wipe the camera with the damp cloth and then dry it with a dry cloth. If you have used the camera at the beach, use a cloth soaked in clean water and wrung well.
• If any dirt, dust, sand, or other foreign material adheres to the periphery of the lens cover after use, or the lens cover does not move smoothly, wash the camera using the method described on P. 66.
Monitor:
Lens:
• Blow dust off the lens with a commercial blower, then wipe gently with a lens cleaner.
Battery/Charger:
• Wipe gently with a soft, dry cloth.
Note
• Do not use strong solvents such as benzene or alcohol, or chemically treated cloth.
• Mold may form on the lens surface if the lens is left dirty.
Apr 20, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Washing Machines Logo
236 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
