Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Hitachi 53sbx59b horizontal wave lines
By skotkolr on Sep 13, 2008
Hi I usually answer questions on this forum in the lcd section but i picked up this Hitachi 53SBX59B and the interior components seem in good condition. I get a image on the screen IE vid 1 for about 10 seconds then the picture collapses to a series of horizontal wave lines across the screen(red blue green) I am thinking the high voltage p/s may be bad, all the main projection tubes seem to be working but very low intensity at thier bases. I am used to seeing more light than they are giving off. Magic focus just causes the waves to flashe on and off and after the magic focus for the convergence is done it just has wavy horizontal colors across the screen again all green led's are lit inside on the second board and I have air cleaned the inside out so the dust is gone. no evidence of bad or blown caps
let me know what you think and if i can do a little testing on output of the high voltage unit tell me how to check it and i will get back to you with numbers
thanks
Solution #1
posted on Sep 14, 2008
Somewhat Helpful)
Abrsvcs
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1822 votes
I would check the main power supply for a bad filter cap. That could cause the wavy lines. The different colors are probably a problem with the convergence circuit. Try resoldering the convergence ICs first. If that does not resolve it replace the ICs. Also check for low valued resistors in that same circuit or pico fuses.
Dan
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
our tv just stopped having a picture and is making a sound in the back like a rusty wheel
Answer
My two year old WD-65735 TV's screen is hard to view unless we turn up the brightness and turn off... (More)
Answer
Model #HD50LPW62A, the sound goes out for short periods. 1-10 sec, It happens with no frequency, but... (More)
Answer
color red on my projection tv went really out of wack and i cannot put it back in place. i was... (More)
Answer
need a remote code for the universal platnium link remote... remote doesnt work!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
