Question about Hoover Washing Machines
Hoover 700lc won't start
Hi, my Hoover 700LC won't start, the is pressure in the hose at the point of connection to the washing machine, but it appears as though it has shorted out. Is there a fuse or something I can check?
5 Suggested Answers
  • 1462 Answers
SOURCE: Power is on - fuse
probably the door interlock. easy part to fit and not too pricey
Posted on Jul 10, 2008
  • 75 Answers
SOURCE: Hi there My washing machine
no,hot water connection is not the problem.the problem is of the machinery as it must have been jamed as it ws not used for so long.
Posted on Sep 03, 2010
SOURCE: My hoover washing machine top
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
Posted on Oct 10, 2011
machinetech7
  • 1344 Answers
SOURCE: hoover 700lc is putting grease on clothes
The only part of the washer that has oil or grease is the transmission. This is a very bad sign because it says the transmission is leaking and the center seal is also letting the oil grease come through. I would start looking at new machines because it wont be cost effective to repair if you pay a service comapny and if you've never done one its not something you want tot learn on.
Posted on Apr 29, 2012
700LC will not spin
The older Hoover had a problem with the clutch drive seizing. Sometimes it was caused by the aluminium housing on the gearbox breaking or cracking. When this happens, the clutch pawl doesn't release the clutch gear properly. The clutch stays in the locked position and then it wont allow the tub to spin. Its not often the top bearing fails. A common sign of gearbox / clutch failure is a brown oily stain spread all over the inside of the cabinet in line with the bottom of the gearbox. This means that the gearbox has slowly filled with water through a failed gearbox seal and when it gets to this stage, its not an economical repair. Time for a new washer unfortunately.
Feb 22, 2014 | Hoover Washing Machines
I ne to figure out the frequency code for an Excalibur AL_700LC
The correct remote transmitter for the AL-700LC is the AU-3TLC. Unfortunately that particular remote is discontinued but there is a suitable replacement, AU-3TAL3. The AU-3TAL3 only differs in case style. The remote can be purchased from the Omega Research and Development, the makers of the AL-700LC, website.
The AU-3TLC and AU-3TAL3 are trinary (3-state) remote transmitters. Programming the remotes require the cutting of traces on the circuit board. On the back side circuit board, the side without the components, there are solder pads labeled 1 through 10. Each solder pad has to tracks / traces, one above and one below. The traces on the numbered side of the solder pad is the positive side. The inside trace, no number, is the negative side. When both traces for a particular pad is cut, the state is neutral. You need to match the cut traces exactly as your original remote.
The best way I have found to cut the traces is to use a dremel type tool. You can also use a tip of a knife, a scratch awl, or any sharp pointed tool to scratch the trace away until an open is achieved. Just be careful not to cut any traces that should not be cut.
Oct 15, 2012 | Vehicle Parts & Accessories
Hoover 700lc is putting grease on clothes
Apr 28, 2012 | Hoover Washing Machines
Tap to washing machine is working fine, but water only trickles into the machine when filling. What can I do? Hoover washing machine model 200 MONZL
hi just read your posting.1st remove both inlet hoses from the taps and the machine.Check if there are little filters on the ends of the hoses,They could be blocked.Next check the filters on the water valves.The water valves are where the hoses connect to the machine.If the hose and water valve filters are clean then you will need to replace the water valve.Did you check how much water pressure is coming out of the taps?Please reply on how you got on and with additional information and I am sure I can help you on this problem.Looking forward to your reply.
May 20, 2011 | Hoover Washing Machines
Hoover 550M washing machine - taking ages to fill, water is just dribbling out. Was fine when started, lifted lid to put in clothes and now only dribbling out. Water pressure in rest of house seems to be...
Check the inlet screen on the hose connection on the back of the machine. This may be clogged with debris, also make sure you hose is not crimped. You can unhook the inlet hose and put it in a bucket and turn it on to see how much water is actuall coming thru that hose. I suspect some type of blockage in the inlet.
Nov 11, 2010 | Hoover HTC243 Top Load Washer
My hoover hpe236. The lights flash intermittently
Hello
Maybe the wire to the light has a loose connection or your bulb may need to be replaced.
ilona
Aug 02, 2017 | Washing Machines
Issue with Water Pressure
blocked dispenser box Regards Advisor
Aug 22, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
