Question about Kelvinator MDB202RB Dishwasher
KELVINATOR DISHWASHER DO NOT PUT IN ENOUGH WATER
  • 641 Answers
It's look like a water level switch issue. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you should find it easily. You can either clear any obstruction in the tube or to replace the switch. Good luck !
Posted on May 28, 2006
My kelvinator dishwasher kd12mm1 do not heat the water?
The heating element or control may have failed.
Apr 07, 2018 | Kelvinator Dishwashers
I have just reeived a Kelvinator dishwasher KD12WW. I have only a cold water outlet can I still wash with it
I found a site that is important for you to down load the site is ns323666.ip-37-187-156.eu
It is a pdf version of the instruction manual for the dishwasher
I notice that one of the instructions is quote" when using your dishwasher , you should prevent plastic items from contacting the heating element" un quote
most all dishwashers heat their own water above what human hands can stand so from that statement you can use cold water inlet only and the machine will heat it to operating temperature
I got that site by going google and typing in --kelvinator kd12ww dishwasher
then I selected site manual-kelvinator kd12ww dishwasher clicked on that and that address came up with the pdf manual
there are other sites that have parts manuals and heaps of other information
call your local kelvinator service agent and ask them about a heating element
Sep 30, 2016 | Kelvinator Dishwashers
User manual for kelvinator extreme clean KD12WW
Need to check if Rinse Aid is not exhausted in the dispenser. It could also be necessary to increase the flow rate of rinse aid. Also make sure the dishwasher is heating water as some dishwashers use steam to dry. If heater is faulty the steam will not be there.
Apr 21, 2014 | Kelvinator Dishwashers
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
WATER NOT RUNNING INTO DISHWASHER
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 14, 2010 | Kelvinator MDB121RF Dishwasher
Kelvinator kd14ss
This is a common problem with this machine. Per the manual E4 indicates that the machine is overloaded but this is incorrect. The machines has actually become water logged due to a design fault whereby some water is allowed to pool at the bottom of the machine rather being efficiently drained. Note that the area where the water pools is not rust resistant. To temporarily overcome the E4 error, tilt your machine backwards and the excess water will drain out the back corners. Remember to put some towels down to avoid a big mop up operation afterwards. I live in a coastal area so drain the machine this way once a month and then open up the back of the machine (don't do this if still under warrantee) to dry it out completely to minimise the rust.
May 26, 2008 | Kelvinator 24 in. MDB222RB Built-in...
Dishwashers Logo
580 people viewed this question
Top Kelvinator Dishwashers Experts
Renee Knafel-Bullock
ray gallant
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
