Question about Toshiba 46HM95 46" HDTV
Video input problems
Brand new tv which seems great except i'm chasing my tail trying to get the video 1, 2, and 3 inputs to function. the audio works fine on all three inputs but i get no video signal on any. i've tried both s-video cables and the standard rca connection (not both at the same time as i know this won't funcrtion properly). at first i thought it might have been an interface problem thru the receiver so i eliminated the receiver and made connection directly to the tv inputs. neither vcr or dvd will provide video signals but i get both left and right audio. i've also tried different cables to make sure i don't have a bad connection somewhere. any ideas? oh yeah--the dvd works fine thru the component rgb inputs but i get nothing using the standard rca inputs. help!
    President:
  • 3,130 Answers
If its a brand new set and never worked from the get go I bet ya 10 to 1 that theres a plug or clip lose in the set someware. Hope ya got a warrantee as you should have unless you bought if off A corner someware. Call the repair service # thats in the owners manual to get it fixed asap. Good Luck
Posted on May 28, 2006
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Sony STR-DG710
try to reset the tv throught the menu options, if that fails then the video inputs or video components in the tv needs repaired, if you have a "S Video" input you could use that or have the TV repaired.
Nov 14, 2007 | Audio Players & Recorders
We have an Electro Brand Inc. DVD Home Theater System, model # STS2891-1. We cannot see ANYTHING on the HDTV screen that would allow us to access the SETUP menu. Please help!!!!!! We have tried...
First, does your TV have HDMI connections? If so, you need to connect your home theater to one of those (it doesn't matter which one, although I would choose HDMI1 (you will, of course, need an HDMI cable for this). You will see nothing on your TV screen until you make that connection. Once you do, using the Electro remote, you should be able to access the "set up" menu.
Jul 15, 2011 | Audio Players & Recorders
How to I change the video input? i.e. I got a digital TV box and need to put it to video input 1. How?
  • On the back of your TV are all your inputs/outputs.
  • On the far left is your Video 1 Input.
  • The top input is your Video (Yellow AV cord)
  • The middle input is your Left Audio (White AV Cord)
  • The bottom input port is for your right Audio (Red AV Cable)
  • After you have all the AV cord up as I have explained then push the "TV/Video" button on the remote until "Video 1" appears on the screen.
  • In the event you should want to use Video 2 sometime then hook the cords up the same way except in the Audio 2 port in the back of the TV.
  • Each time you press the "TV/Audio" button you will cycle through the Inputs until you come back around to TV.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Panasonic CT-32SL13 32" TV
Greetings- my denon avr2802 is connected to ps3 for blu ray movies, games and music. The ps3 image goes directly to tv with hdmi and sound from ps3 goes to the denon using digital audio cable. Sound for...
Set the receiver for auto audio input - I think that you are getting caught out between MPEG and DTS audio. If you have the wrong one for the audio source then you hear nothing.
Mar 07, 2010 | Denon AVR-2802
Only audio works. No video. Worked fine last time. Tried new cables. Tried video 1 and 2 inputs to tv, still sounds great but no picture. T.V has no problem with video camera in either...
if the camera works, and you tried new cables.. it sounds like the problem is in your dvd player. make sure you have the video cable plugged into the correct slot on the dvd player.
Mar 01, 2010 | Oritron Televison & Video
New remote won't program to switch to cable input.
That's a problem with universal remote controls. Often they don't control every function of the TV. They just don't have the buttons needed to control everything the original remote did. You'll have the most basic controls - power, channel and volume up and down - and maybe a menu button. But you'll frequently find other things don't work, like switching inputs. There isn't anything you can do except try all the codes for your TV brand and see what each button does. You might find that the buttons have different functions depending on which code you've entered. You might also look for another brand of universal remote that has more functions available.
May 23, 2009 | Daewoo Televison & Video
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Toshiba 46HM95 46" HDTV Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
