Question about Samsung SyncMaster 17 in. LCD Television
Samsung SyncMaster 170MP....Need code for IR/UHF Pro remote
Have DishNetwork using a 6.3 IR/UHF PRO remote. I tried auto searching for the code, but not luck. Any suggestions / solutions would be appreciated.
SOURCE: COMCAST REMOTE AND SAMSUNG TV
I was having the same issue with a Samsung 4053 40"
Comcrap had no clue.
Their phone rep suggested I come in and trade out the remote. That seemed unlikely if others are having the same experience. It is also unlikely a phone rep would have any answer other than what on the web page.
I used 5 digit code "10060" and it worked got the double flag from the remote like Comcast's documentation says. It turns TV on and off and works volume. So far so good.
The key to figuring it out was getting the double flash on the remote 4 digits didn't 5 did.
The moral of our story? Comcast has no clue what they push out the door. I guess that isn't a surprise to anyone.
Posted on Jan 13, 2008
SOURCE: SAMSUNG BN59-00599A REMOTE
http://downloadcenter.samsung.com/content/UM/200705/20070515083727984_BN68-01167A-01L02-0331.pdf
Pages 18-25 should be what you need.
Posted on Dec 01, 2008
SOURCE: Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Posted on Oct 03, 2009
  • 732 Answers
SOURCE: Samsung SyncMaster 940n monitor that turns on then goes black
rcpips, You may need to replace one or possibly 5 -8 aluminum can "electrolytic filter capacitors" on the "switch-mode-power-supply/CCFL inverter board. If, as you say "works for 5 or 6 seconds" then that means that fuse is good. Another thing you will need to inspect SMPS board for is "cold" "frosty looking" solder joints where the components (surface mount or through hole) are soldered to the copper circuit traces. May need large magnifying glass or low power inspection microscope to locate them. Resolder any that look bad or loose. Some solder joints have thinner than "hair" thermal fractures that can also cause YOUR TYPE OF SYMPTOM!! PARTS: digikey. mouser. newark. and possibly Radio Shack. If buying filter capacitors, make sure they are rated 105 deg C only!! NOT 85 deg C!!! If caps need to be replaced (swollen, leaky) be sure to tell us the brand name you find installed on your unit! CAPXON, ELITE, JUN-FU are just 3 that you don"t want to find in your unit. BAD news if you do!! If DIY suits you, remember to document with "close-up" digital stills your unit tear-down, so you can reassemble unit without any "extra" parts laying on kitchen table!! Filter capacitors are polarized. You put them in + to +, - to -!!! if you put them in backwards they go BOOOOMMM!!! Hope this helps a little. lmistyrel on aim or 12fixlouie at fixya.
Posted on Jan 30, 2010
Testimonial: "12fixlouie has been most helpful in helping me find a solution to my monitor problem."
SOURCE: we have a samsung syncmaster 2333hd and we need a
look to avoid any headaches... get the original one from the manufacturer or agent. The "Universal" ones are plagued with problems. If you do go the UR, way, make sure the seller shows you that it WILL work with your model of set. Ensure you read it in black & white.
Posted on Feb 15, 2010
Auto program dish remote 21.0 IR/UHF Pro to Epic Sound Receiver
DD Cox,
I can definitely provide more information. Without knowing the model of the sound system, I am unable to provide specific codes. Below I will include a link to lookup codes, as well as the steps to address the remote.
Link: http://www.mydish.com/support/apps/remotecodes.aspx
Addressing Remote to DVD:
1.) Press and hold the clear AUX button until all mode lights light up.
2.) Release and AUX light will be blinking.
3.) Press 2 and enter the code. (Example: If the code is 639, enter 2639)
4.) Press pound (#)
5.) Try functions (Power, Volume, etc..) and see if it is working.
6.) If no function, repeat steps 1-4 with another code.
Let me know if you have any other questions!
Tommy Faust
DISH Social Media Representative
Jan 22, 2013 | DISH Network IR Remote Control
I have a 4.4 ir/uhf pro dish network, i did oened and i an not close it because does have a part that i do not know how it goes, this part is only in the #2 remotes thats mean in the 2nd tv and has a part...
Himarieyvette2, my name is Mike Houston of DISH Network and I was going over yourpost and see where you're 4.4 IR/UHF Pro remote did not have a part. If youtake out the chip it is a two sided tab and will allow the remote to work forTV1 (Green side) and TV2 (Blue Side). I will send this link http://www.dishnetwork.com/SupportSection/setup-remoteto help with the steps to setup the remote.
Feb 26, 2011 | Universal Remote Control DISH Network...
I am trying to find the codes for a Dish Network remote ( 6.4 IR/UHF PRO ) to program TV Emerson LC320EM1 and if possible for the Lenoxx Sound Home Theater. Thanks in advance for any help.
Hello, my name is Daniel Busa with DISH Network customer service below, are the codes for your emerson tv and a limk with instructions if the codes don't work try the powerscan method in the link I gave you.
632,516,627,654,720,532,500,526,534,536,541,573,,590,636,642,648,652
Jan 06, 2011 | DISH Network IR Remote Control
What is the code for dish network remote 21.0 IR/UHF PRO?
Hello!!! Your post is not clear on if you need to program the remote to the receiver or the tv, but here are steps to program to both. Just follow the link provided below, and you will be good to go!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
Dec 09, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Jan 25, 2009 | Durabrand HT-3915 System
Remote code for Sylvania LC420SS8
Hello frozen thank you for using FixYa.com for your answer my name is David.
Well I had to do a little bit of a search but one of these codes should help you out.
Sylvania 506, 525, 536, 566,
568, 569, 573, 600,
610, 652, 654, 656,
659, 660, 664, 665,
666, 671, 672, 674,
677, 723, 724, 729,733
I retrieved these from the following link that help you again in the future
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/IR-to-UHFProUpgradeKit132327.pdf
thank you again for choosing fixYa.com for your answers.
Nov 08, 2008 | Sylvania LC320SL8 Television
Draining batteries
probably caused by a short inside the remote, it will need to be replaced
Jul 13, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Samsung SyncMaster 17 in. LCD Television Logo
256 people viewed this question
Henry  Thomas
Henry Thomas
