Sony KP46WT510 convergence
I have ghosting (blue) on my rear projection and it seems to be a convergence problem. I can solder/desolder and do have multimeters. Can you please help me fix this problem?
  • delguercio24 Sep 13, 2008
    I forgot to mention that my tv goes in and out with these symptoms. Sometimes it will be fine for an hour then all of the sudden the ghosting appears. Could be be from the fuses or the IC's?
  • popbumper Mar 03, 2009
    Yup, I have the convergence issue as well. I have opened the back of the TV, I know what needs repaired, I am ready to do the work.
    QUESTION: Do I need to DISCHARGE all three guns to avoid shock from the tubes? I can do the board repair, but I don't want to mess with HV. Please advise, thanks.
    Chris
    Novelist:
    Champion:
  • 203 Answers
This is an easy fix, you need to replace the STK's they are located on the heatsink that is near the back of the set on the deflection board. The part locations for these are IC8002 and IC8001. Part numbers are STK392-560. You can buy them at bdent.com Good luck let me know if you need more help!
Tim Nolan
Posted on Sep 13, 2008
  • experttv
    experttv Sep 13, 2008
    I forgot to mention that you need to be carefull desoldering the IC's there are a bunch of surface mount resistors right by the pins that are easy to nock off the board. Also if you are certain that this is a convergence issue then replace those parts, if you have a doubt in your mind then please post a picture of the ghosting and I will let you know if it is or not for sure. let me know if you need more help!
    Tim Nolan
Tv started ghosting in red green and blue
The tv is have a problems call convergence,it dead.U have all the tools like soldering iron,solder and desoldering pump.Know basic soldering?The convergence fuses FL231 three of them on the right side of FBT,a big block of plastic of a flyback transformer.Resoder the FBT,replaced the convergence fuse FL231 in the middle.The Ebay.com sell the convergence fuse.
Aug 25, 2010 | RCA HD52W59 HDTV Projection Television
My sony projection xbr 57 in hd is ghosting
if it's red, blue, or green ghosts, then you need new convergence chips, stk 392-570, have to be soldered in.
Sep 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Hue wont align and causes ghosting
you need to replace the convergence ICs and pico fuses. The KP46WT510 convergence repair kit at the following link works for your model as well and the kit comes with instructions on how to do the repair. Its listed under the convergence repair kit category.
Feb 15, 2009 | Sony KP-51HW40 51" Rear Projection...
Red ghost in the screen
you can get the KP46WT510 convergence repair kit which will usually repair that issue at the following link the repair kit contains both ICs six pico fuses and 4 of the feed resistors also includes instructions with pictures on how to do the repair.
Feb 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My sony 46 kp46wt510 panel tv has red outline on images
its more likely needing the convergence ICs replaced. You can get the convergence repair kit for your model at the following link which contains both IC the six pico fuses and four of the feed resistors, The kit comes with instructions. Heres the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
Your Convergence ICs need to be replaced. If you need anything further let me know.
Jan 23, 2008 | Zenith R40W46 40" Rear Projection...
Blue Ghost
You need new convergence ICs . They cost about 10.00 each you will need two. They are located on a large aluminum heat sink with an STK number stamped on them. They will have to be soldered in. If you can solder you will be able to do this repair yourself. Let me know if you need ay additional Info.
Nov 14, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
476 people viewed this question
Top Televison & Video Experts
Electro Med Services...
