Question about Frigidaire FGF355 Gas Kitchen Range
Gas isn't coming on for "Bake"
Hi. When I turn my oven on, the ignitor comes on but I don't hear the gas running and the pipe where the flames come out doesn't light. The broiler is working and I can hear the gas running just before it lights. The burners on the stove work as well. I've taken the plates off of the bottom but the final plate is giving me trouble. I can't get it off because the way it's placed in there makes it impossible to remove. I was hoping to clean away food by the gas valve and this would solve the problem. But I think the problem is greater than that even if I get the bottom plate off. Can you please help me? I have cussed way too much today and my husband and dogs are becoming scared of me!
Thank you, Tera
  • tbearevans Sep 13, 2008
    The ignitor has plenty of amps. Still no gas. The ignitor took a while but it got bright all the way through. Thanks for helping though!
I have a Frigidare stove the one with the display which you dial the temp and turn on to bake and broil stove.
My ignitor lights up get hot, so smell of gas and no flame what can it be what part do I buy and where do I replace it?.. Someone check it out and said the switch to turn on the gas to light the oven is not working.
Please Help
Nydia
Posted on Nov 29, 2008
  • 725 Answers
First the ignitor must glow very bright / compare the broiler ignitor to the bake on... the ignitor must pull 3.6 amps to open the gas valve... so even if it does glow it must glow bright and evenly to pull the 3.6 amp... you can test it if you have an AMP meter...
Gas valve do fail but it is rare... it is most likely a weak ignitor... hope it help please let me know...
Posted on Sep 13, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 14, 2008
    so it pull 3.6 AMPS and the gas valve did not open... you do need to replace the gas valve in the back bottom... Sorry to hear that... the ignitor is cheaper and easier to replace... let me know how it works out...
  • Franklin Ouchida
    Does it take much longer then the broil igniter to get bright ... that is a sign of a ingiter failure
When you turn the knob you dont smell gas, don't here the click of the igniter, but would like to light the oven manually. Can you help me please.
you can't manually light the oven with a match anymore,you have an electronic ignition in the oven or an ignitor part number 5303935066 and it's around 60 dollars.you have to remove the racks,remove the floor of the oven and then remove the cover and you'll see the ignitor in the back screwed to the tube usually with two 5/16 inch screws. set the oven to bake on 350,if the ignitor glows but doesn't light in 40 seconds it's bad,if it doesn't light at all you can unplug the ignitor and check it with a meter for continuity but most likely you have a bad ignitor.wet a paper towel and wet the two screws,they will come out easier,you can't use wd or anything like that because it will smell when you turn the oven on so use water, if you can see where the disconnect is to unplug the ignitor unplug it or when you get the screws out cut the two wires close to the ignitor,the new ignitor comes with ceramic wire nuts so you can connect the two wires you just cut to the new ignitor,the wires on the new ignitor will be long,you can screw the new ignitor on,leave around 6 inches of wire on the new ignitor so the wire connectors will be away from the tube and not up near the floor and if you have the ignitor screwed on you can see how long to make the wires,cut the wires and strip the ends on the old and new wires and wire nut them together.then turn it on to bake,when the ignitor starts to glow it sholud lite the flame in less than 40 seconds.hope this helps you out.one more thing don't touch the piece of the ignitor that's inside the metal bracket,they break very easy.good luck and have a great holiday.
Nov 20, 2011 | Tappan TGF320 Gas Kitchen Range
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Jul 20, 2011 | Ovens
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Stove top gas flow and gas oven bake cycle not igniting
This most likely is the solution for the bake problem you have:
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 05, 2010 | GE Profile JGP636 Gas Cooktop
Oven's ignitor is bright, I smell gas, but it won't lite.
if ignitor is brt orange to white its hot enough to ignite gas,either the flame sensor is giving wrong signal to control board and not opening gas valve or signals the gas valve to shut off gas before ignition,also your flame sensor could be faulty or control board is bad
Jul 26, 2009 | Kitchen Ranges
Bottom oven will not heat up.
Jun 11, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Oven, Broiler inopperable
Sandwich, is it your bake or broil thats not working? You have two ignitors, one for bake and broil. One of them is your culprit. This is not a hard job. The post header says broil not working so the part number for that is WB13K0003. Bake ignitor is WB13K0004. To get at the bake ignitor you have to remove the oven bottom inside panel, remove the flame spreader (both easy). The click you are hearing is the board relay sending power to the ignitor. The ignitor has to draw so many amps to open the gas valve. The oven is pilotless. Catriver..post back.
Apr 21, 2007 | GE JGBP28 Gas Kitchen Range
Oven doesn't work
Oct 31, 2006 | GE Profile JGBP79 Gas Kitchen Range
Frigidaire FGF355 Gas Kitchen Range Logo
397 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
