The problem is a shaky picture with a static line that's vertical when watching regular TV. This problem does not happen when not watching in HD through our Myth TV (DVR). Closed captioning does not flicker but the picture behind does. This in on a rear projection big screen Toshiba 50HX81 52 inch HD ready TV.
  • 19,396 Answers
Regular TV, you mean by the aerial and internal tuner, if it is like that, then it is a problem with the TV tuner board.
If by regular TV you mean an external TV box, then the TV box is faulty or you have a cable or ferquency problem.
Posted on Sep 13, 2008
  • Ginko
    Ginko Sep 13, 2008
    Try to connect to an additional tv receiver, if it work, then it is channel receiver.
    If it is an external TV box replace it.
    If it is the internal TV channels that do not work, then you will probably need a technician.
    To get repair service you can call the number listed on the owner manual.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Vertical purple lines appear when watching tv but not dvd
You unit should be under warranty. contact the manufacture for the nearest authorized servicer.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
A horizontal line on the top of the tv when viewing some channels
that is normal, many tv's have this, just change the screen size, does this happen on hd channels too? or only regular channels?
Jan 21, 2009 | Vizio L32 32 in. LCD HDTV
Help
Considering that it's a LCD type, that is not a good sign; the individual pixels are addressed by a matrix and that kind of indicates that a vertical driver for that column is failing and these are often not replaceable by human hands having pin spacing too close for shaky techs.
If you want to confirm that this is heat related, you can buy a can of freeze spray from any electronic supply house and spray into various slits in the housing to see it you can restore that column temporarily with it.
Sep 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
LCD TV Picture scramble/static/break up...
picture break up on all digital chanels
Feb 19, 2008 | Televison & Video
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Vertical line on KDL-32s20l1
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Aug 27, 2007 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
