Question about Car Audio & Video
Sony Xplod 2-Channel 1000 Watt Amplifier trouble shooting
I have a sony Xplod amp and it doesn't seem to be working properly. The other sony speakers in the car seem to have more base than the ones running through the Xplod. I have checked the settings on my cd player and they are set to max for the Sub. Am I missing something?
  • Anonymous Apr 24, 2009
    i have a 1200w sony xplod twin channel. it has been working fine since i had it. now the amp comes on when it wants to, which is for like 3 mins at a time. the red light flashes sometimes when the sub is on. i havent checkedthe fuse yet because i get high and forget about it. does anyone know whats up?
  • 631 Answers
What's the model number of the amp?
What speakers do you have on the amp?
Are the speakers moving significantly at high volume?
Posted on Sep 14, 2008
How do I connect a Sony xplod 1000 watt 2 channel amp to 1 10" dual 4 ohm voice coil 1500 watt planet audio subwoofer?
Connect one voice coil to one channel of the amp. Repeat with the other voice coil. Do not bridge the amp as your only choices would be series which would be an 8 ohm final load and cuts the amp power in half or parallel wiring which results in a 2 ohm load and very few Sony amps currently made can handle being bridged to a 2 ohm load.
Aug 28, 2016 | Sony Car Audio & Video
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
May 07, 2011 | Sony Xplod 800W Class AB Bridgeable...
I have a sony xplod 1652z 1000 watt amp and want to hook up 2 subs and the speakers that are already installed in the truck is that possible?
thats not a good idea because you are running too many speakers off that amp it it could possibly blow a channel or the whole amp. trust me i've done it
Jun 10, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
What size amp do i use with 2 1100 watt 10" sony subwoofers
I have the same set of speakers and im running a kenwood 2 channel amplifier thats bridged and it works well.
Jan 30, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub wiring
IF THE RMS IS 800 THEN THAT IS THE MINIMUM YOU SHOULD RUN TO THEM. IF THE MAX IS OVER 1000 WATT, YOU SHOULD BRIDGE ONE SPEAKER TO EACH CHANNEL. YOU WILL PUSH THE MOST POWER TO THEM THAT WAY. MORE POWER = MORE BASS
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car Audio & Video Logo
1,166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
