Computers & Internet Logo
Posted on Sep 09, 2011
Unable to load card dependent library - ActivCard Gold 2.2 for CAC (gacg22cl)
1helpful
My problem is the program will not start, I get the initial start up screen which consists of the following Videostudio Editor Movie Wizard DV to DVD Wizard I then click on any of them and get a...
most likely your problem lies in the graphics card in your computer anda.coba check again how great your graphics card, because Corel require a large memory graphics card
Unable to load library
looks like the error happens when you use a corrupted or bad specific transition in you production. I recommend you update your direct x drivers to the latest, also update your flash to the latest. Then if the problem persists, take the transitions out of your production, and troubleshoot by trying each transition until you find the one that causes the "unable to load library" error. (if the updates dont do it) check your direct x version and tests by running DXDIAG at the start run menu hope that helps you!
I added to much music and it crashed
I use a microsd to load files that i havent tried on the device before, to test safely. If it crashes then i can simply remove the microsd and clear it. If the "bad" or incorrecly encoded files are loaded onto the internal memory of the device then you will be unable to clear or bypass the "building library" stage and the device is bricked. Take it back to where you bought it and get it replaced if this happens, that's what I had to do when I bricked it.
Maybe we all need to write to iriver and request much improved firmware that allows wiping of the internal memory BEFORE the build library stage as well as the option to disable or an improvement of the "build library" functionality. A simple solution would be to set a flag in a config file whenever files are added to the device and it doesnt do a build library unless the config flag says new files are present and that it is required.
Unable to load music library in to machine, I copied and pasted to the MP3 and see it but the machine says empty disk
hey there, i think the 1 you copied is just the play list since you copy it on your music library, if the size of it is just a small bits.you have to copy it or drag it manually, just go to the actual folder of the music or mp3, then copy it, not on any media library of audiosoftware you are using.
1helpful
Unable to load file from PC
1.) Select Memory Card in the handset : Main Menu > Multimedia > Music Library > Menu Key > Switch Storage Device > Memory Card.
2.) Connect the Handset with PC using Data Cable.
3.) You will get a prompt in the handset : Use as Mass Storage : Yes
4.) Go to My Computer, you will find a removable drive.
5.) Copy and Paste the Songs and Pictures in Removable Drive.
6.) Make sure that the keypad of the handset should not be closed during the entire process.
22helpful
Unable to load vopyl.dll
can play alexander unable to load voplyl.dll library
7helpful
5answers
Corel x2 problem: Unable to Load Library when sharing to VCD
Hey everyone, I faced the exact same, excruciatingly frustrating problem. After a quick search, I found forum threads telling me that when Corel Video Studio was modified to suit Vista, something about its 3D transitions got messed up.
So, if you face this problem while using Corel Video Studio on Vista, check that you have removed all 3D video transitions and try rendering again.
My Casio Exilim EX-Z57
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1helpful
Pixe view TV Tuner CArd
you can grab the xp drivers here
http://www.prolink.com.tw/
and for watching tv, you may be able to use this
chris tv lite freeware
http://www.softpedia.com/progDownload/ChrisTV_Lite-Download-2301.html
Taking books I down loaded at the library off
It depends on the agreement you have with the library, most in the country allow 3 downloads before it quits, to avoid people passing them around for free. Overdrive is the choice of most libraries now and they all have DRM type of capabilities. The player will play only what it is allowed to by the file.
Top ActivCard Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an ActivCard Computer and Internet Expert? Answer questions, earn points and help others
