Question about Maytag Dryers
My Mag neptune dryer shows HP and stops drying
  • 750 Answers
Hi again mssunnybunny,
I just thought of something,
You did not give a lot of details so pose this question just in case!
You only said, Your Mag Neptune dryer shows HP and stops drying!!!!!!!!!!!
1.Does it go but not get hot and not drying??
2.Or does your dryer not go and then make a loud humming sound like it's trying to go??.
If # 2 is the description and this was the case, then you need
a new motor!
Posted on Sep 14, 2008
Maytag neptune mdg9700bww dont stop drying by it self
could be dirty electrodes, find the two shiny metal strips in the dryer drum maybe in the front, so you will stick your head in the drum and look back at the lint filter to see them. Clean these with window cleaner and try again.
Jan 22, 2014 | Maytag Neptune MDG9700A Gas Dryer
My neptune dryer will not start. the estimated time display is 8.8.
We wewr drying a rug when the rug wedged somehow. The dryer just stopped and will not start.
Oct 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hi, My dryer suddenly stopped drying. No power to
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting...
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune dryer MDE 6700AZW Stops working
try a simple test before you try to gain axcess to the console parts unplug the power cord 1 min plug back in and put in time dry not auto or it will time out quickly without wet cloths see how it does and if this not solve you problem repost with model #
Aug 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
67 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
