Question about Belkin (F5D7231-4) Wireless Router
Belkin N wireless router
Slow connection with wild blue, also slow downloads
Need to port for ward utorrent
Posted on Sep 26, 2008
  • H Hunter Sep 26, 2008
    can you help
I have just got a Belkin Wireless Modem Router F5D7632uk4A v7000. i got it connected to the internet but is SO SLOW! i have tried to speed it up but i dont know what else to do?
try disabling the firewall in the router and updating the firmware would be the best option. here is the link.. download the one that belongs to your router's version: http://en-au-support.belkin.com/app/answers/detail/a_id/2600/p/2312
u need to update the firmware from the router's set up page acsessed by 192.168.2.1 from a computer connected to the router with a cable.
Jan 22, 2010 | Belkin (F5D7633UK4A) Wireless Router
Slow connection speed
Blu Ray players, draw alot of interference into the wireless router. Try moving your router into a different place, or somewhere away from your Blu Ray player.
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless router disconnects from wildblue every 2 min
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the Belkin wireless router away from walls and if possible move the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. changes the default password, setup encryption use WAP2 or WAP, change the default SSID, turn off SSID broadcast, and for added protection, enable MAC address filtering which allows the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 23, 2009 | Belkin (F5D5231-4) Router
Blue Ray connection to Belkin G router
your wireless router is encrypted. To remove encryption, go in your computers web browser: http://192.168.0.1
That will take you to your LAN Administrator.
Follow the simple wireless setup for an unsecured connection or setup your blue ray connection and create your own passphrase or WEPKey.
Hope that helped!
Jun 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My wireless router is slowing my internet connections
could be a possibility that someone is hoping on your wireless network and doing some massive downloading. If that's not the case, try replacing your belkin unit.
Apr 24, 2009 | Belkin (F5D5231-4) Router
I lost my Belkin disk and can't setup my router
You can easily download your software from belkin by going to the support and downloads page. match the model number located on your unit with the list they provide and download the software. If you have a slow connection and would rather set it up, they have instructions for the different types of setups you can do MANUALLY.!
Jan 05, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My Belkin F5D8053 is working in low strength
If you're encountering a very internet connection on your router, this is can be a problem with either the internet connection from your modem or the firmware of the router should be updated, first thing that you can try is to update the firmware of the firmware of the router, you can download the latest firmware of it from Belkin web site then after that observe the connection if you still have a slow internet using the router , Try to check now the internet from your modem by connecting a computer directly to your modem and if you still have the same problem internet connection from your ISP is the problem so you can contact them about that..........
Nov 11, 2008 | Belkin Wireless-N Wireless Router with...
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Weak connection
HI,
As you have changed the router still the connection speed is slow, in this case it's better to contact your ISP get the line tested or a proper signal strength.
Also conduct a speedtest by going to the website internetfrog.com....indications are towards a line fault.
Apr 23, 2008 | Belkin (F5D5231-4) Router
Slow speed with my Belkin G Router!!! Help!!!
alright figured out a way to speed up the connections
under firewall - Disable it. Must be slowing down everything. Just make sure you have at least windows firewall (XP) or something else as you are directly connected to the internet now.
Let me know if this helps anyone.
Dec 29, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7231-4) Wireless Router Logo
104 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
