posted by uscsae on May 27, 2006
I have a typical Sony Amplifier that is about 4 years old. The power button which has not changed makes a click when I push it. But the unit does not come on in terms of script or power to speakers or anything. I know the plug works as I tested it. What do you think the issue is?
Best Solution
posted on May 27, 2006
Hi uscsae,
This is usually caused by a blown fuse or a blown capacitor. The fuse would be cheap and easy to fix, the capacitor would be expensive and replacement would be my choice. If you are pretty handy with electronics, unplug it, take the cover off the unit, and look near the capacitor for the fuse. Check the fuse for a break in the wire inside it. You can get these fuses at Radio Shack. Hopefully this is what it is, and will be a cheap and easy fix for you.
Let me know how it goes.
Best regards,
nightdiver
Best regards,
nightdiver
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony STR-DE595 5-Channel Amplifier
Email this problem
Email this problem
Can you Help with these Amplifiers and Preamps problems?
remote codes for sansui audio...
I have an older sansui stereo... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
