Question about Cameras
Pin in bent inside where the card goes in - Cameras
  • Cameras Master
  • 4,738 Answers
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Sep 14, 2008
I can not insert the memory card all the way into my polaroid 12.0mp digital camera what's wrong
The pins for your memory card slot inside the camera or on the memory card itself could be bent, you should be able to see this by using a flashlight to look inside the camera for bent pins.
Aug 24, 2012 | Polaroid Cameras
All the cards i put in say card cannot be used
Take out the card and have a look inside the camera's CF card compartment. If there are bent pins, those will need to be fixed by a camera shop. You may also need to replace the cards if any of their contact holes are bent closed because of the bent pins.
May 14, 2011 | Nikon D70s Digital Camera
DS not reading game
This is usually due to either bent or dirty pins in the card slot, look inside and see if any pins are bent, if they are a new card slot is needed.
Hope this helps
Jul 19, 2010 | Nintendo DS Lite Console
My Minolta DiMage A1 displays "no card" when memory card is inserted. It's not a new card...it's the same 128mb card I've used since I bought it. Any suggestions?!
If you're lucky, the CF card is faulty. It's going to be a very old card now if it's the original one supplied/bought with your A1. You've never upgraded to a larger card in all this time so it suggests you've never needed to. 128 and 256mb cards are virtually worthless now, so I'd be amazed if you couldn't get one for free via Yahoo FreeCycle. You can also try reformatting your card in a card reader/writer, but A1's and A2's often won't recognise a card formatted in this way and it can render them permanently unreadable by all A1/A2/A200 cameras.
If you're unlucky, then you've bent or broken one or more of the pins inside the card slot which connect to your card when you insert it. To check, get a bright torch and look down inside the card slot. Any bent pins will be self evident as there should be a neat double row of pins and missing pins will show up as gaps.
If you have bent pins then you've nothing to lose by trying to carefully straighten them, if you can't or if the pins are broken, then your camera is effectively irrepairable. Scrap A1's and A2's can both provide the part, but retreiving them from the donor camera is really difficult and so far I've never managed to refit one successfully and I've done a few now. A pro repair is simply not cost effective, especially when a perfectly good used A1 goes for around £40-£50 and the better A2's go for around £80-£100. If you're in North America you can expect prices to be even lower.
Jun 24, 2009 | Konica Minolta DiMAGE A1 Digital Camera
When i turn on ds lite it says no game inserted
This can be either bent pins in the game slot, which means a new slot. This is a fairly easy thing to do if you have a small solder iron and some skill.
Or corroded/ dirty pins, which you might be able to clean with some fine abrasive paper and very, very careful cleaning, the pins inside are very delicate. Or your game has dirty contacts, try another game or clean off the game contacts.
Jun 11, 2009 | Nintendo DS Lite Console
Will not take a picture.
Bent/broken card reader pins. Take a flash light and look inside the card reader. There you'll see two rows of pins, 1or 2 will be bent (common problem).
Mar 23, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Not working
Try a different memory card. Some of these cameras may not support large sizes. Try a smaller card such as a 512 or a 128.
Aug 08, 2008 | Canon PowerShot A80 Digital Camera
Memory card won't go in due to wires bent up
The memory card is supposed to slide over top of those pins, they would need bent back down but I can not think of an easy way for you to do that yourself. If you have a service plan, now might be the time to use it.
Hope that helps...
Geno
Mar 29, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Memory Card problems
Remove the card and look inside the card slot of the camera to see if there are any bent pins. If you do find bent pins, you can try to bend them straight (it will be tough). If you do, DO NOT use a metal object. Use plastic or wood only.
Dec 15, 2007 | Canon PowerShot A75 Digital Camera
Cameras Logo
73 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
