Question about Whirlpool Dryers
Temperature control Dryer seems to stay on high temp regardless of setting except for fluff
  • wj_nitzke Sep 14, 2008
    Appreciate the help. Unpluging seemed to do the trick.
  • 750 Answers
Hello wj_nitzke,
Happy to be of assistance,
You said, Your dryer seems to stay on high temp regardless of setting except for fluff
1. Try this first. Unplug the machine and wait 5 minutes before replugging it and then try it and see if that this reset the system.
2.Or your temp switch is faulty.
3.Or your thermostat is defective.
I would think it may be the switch first, if the system did not need a reset as I had you try to do.
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Posted on Sep 14, 2008
  • Neil Golan
    Neil Golan Sep 14, 2008
    Since I did give you the solution to your problem and you wrote me that my solution did solve the problem,Can you please dive me a solved rating at fizya.com!
    Thank You
    huuum
    Comment by wj_nitzke, posted on Sep 14, 2008Appreciate the help. Unplugging seemed to do the trick.
  • Neil Golan
    Please allow me to be credited for the solved fix I helped you with!please go into the fixya.com site and give me a solved rating.
    Thank You so much.
    I'm happy to here that your up and running now!
    Huuum
The fan on the fireplace stays on high and never shuts off. Any suggestions?
Could be a faulty thermostat or fluff and dirt covering the temp sensor. With the unit disconnected, try and remove the front cover and get in with a brush or vacuum and clean the insides. There should be a very thin copper tube with a bulb on the end near the air vent. This controls the temperature. Make sure this is clean. Handle with care as the tube can be broken.
Nov 20, 2016 | Heating & Cooling
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
My washer water stays hot on any temp setting
is there problem with the temperature sensor?It seems the electrical issue.Or may be control panel is broken.
Mar 15, 2010 | Frigidaire GLET1142CS Top Load Stacked...
How do I test the temperature control module for a kenmore freezer model 253.9284013
You need a multi-meter to do this. The temp.control is just a switch that closes on temperature rise and opens on temperaure fall (or when it reaches the desired temperature). Using a meter set on ohms coneect to the 2 prong ends of the temp. control. Set the temp. control on off. You should not have any ohms because hte temp. control is open (no continunity) now set the temp control to 2 or 3 and it should close (the meter will read ohms or continunity)
if it does then the t'stat works. The only other exception is the temp. control will sometimes (this is rare) not properly sense temp. for example, it fails to sense zero degrees and it will either stay on too long to shut off too soon. I only seen this happen like twice in 20 years. but more or less this is how you do it!!!
hope this was helpful
Mar 14, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
95 Lincoln towncar stuck on high temperature setting
u need a new blend door motor. this is a job 4 the machanic cause the whole dash must be pulled back
Mar 25, 2009 | 1995 Lincoln Town Car
Crosley CDE6500AZW heating, but drum not rolling
OK Here is what I think happened. I have heard of this before. You melted a wheel and that broke the belt. This is a simple dryer to repair and parts are not that much. Well worth fixing. Start by popping the top remove the front then get the drum out and inspect the damage.
Mar 01, 2009 | Crosley CDE6000 Electric Dryer
Older whirlpool dryer gets too hot when using automatic setting
After 25 years,your automatic sensor may be bad. RepairClinic.com might have one. Clean everything inside while you're there.
Nov 26, 2008 | Dryers
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
im going to try to help you for free did you not get the tech sheet when you changed out the control board
Feb 15, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
