Question about Faberware FSW343 Electric Wok
Recoating the non stick surfaces of cook pots
Is there any service that will recoat the inside of Farberware pots with non stick surface?
  • 446 Answers
Yes there is it depends on your location, pls visit this site for info
www.thomasnet.com
cheers
Posted on Sep 13, 2008
What to do when your household door sticks due to freezing and thawing?
Take a paper towel and soak it in vegetable cooking oil and wipe the gasket surface with the towel and also the mating surface. The oil won't freeze and the oil will stay in place for a while. ventually the water condensation gets in there and lifts the oil off, so you have to recoat the gaskets every week or two. On refrigerator doors, the gaskets have to be air tight, because water vapor moves easily thru the smallest cracks, so the only way to permanently fix this is to get new gaskets for the door
Feb 25, 2015 | Refrigerators
How do I clean some burned on grease from the non-stick surfact
Villaware might be able to offer some advice but, in general, damaged non-stick surfaces require recoating which can be an expensive process.
Nov 29, 2014 | VillaWare Kitchen Appliances - Others
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
Mar 21, 2013 | Cook's Essentials CooksEssentials 3 Quart...
I have a 12inch cooking pan. stainless steel nonstick. cannot use. non stick surface is comming off.
Howdy, unfortunately, when that happens it is the end of the service life of the pan. If it is a recent purchase, and you feel its a warranty issue, we would be happy to find the contact information of the company for you. If this is the case, please hook us up with the make and mode and we will get going on it for you.
If it is an older pan, there is no safe or practical recoating treatment available.
Best regards,
Farmerbear at FixYa.com
Sep 11, 2010 | Microwave Ovens
Using a Farberware 12 pan coating comming off
non stick coating are volatile and have a short life span depending on the frequency of cooking and washing which wears it out if you are a keen amateur cook/chef my advice is go for HARD ANODISED which is russian space technology in your kitchen or classic copper pots/pans but they are costly,
to help preserve your non stick 1. do not wash straight after let it cool down, 2. always use plastic or wood utensils.3. be gentle,
hope it helps.
Jul 29, 2010 | Faberware Kitchen Appliances - Others
Electric frypan
you can make or try to send this to a recoating company
www.thomasnet.com
for a fresh coating
cheers
Aug 28, 2008 | Rival Kitchen Appliances - Others
George Foreman
There's nothing you can buy that'll reliably recoat the plates, the process of getting something that nothing sticks to to stick to the metal plates is complicated and takes special equipment.  (it's not just paint).
however, there's a company that says they'll recoat the plates for you:
http://www.frypanman.com/intro.html
I don't have any personal experience with them, but I'm checking with them on a pot that a roommate boiled dry until the teflon all peeled off *frown*
cheers.
Sep 24, 2007 | George Foreman G5 Indoor Grill
Faberware FSW343 Electric Wok Logo
977 people viewed this question
Top Faberware Kitchen Appliances - Others Experts
ashburton
Jerry Greenberg
Jerry Greenberg
Dennis
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
