Question about Bosch Washing Machines
Washing machine mdl# WFMC 2100UC WILL NOT DRAIN OR SPIN, AND MAKES A GRATING NOISE WHEN IT ATTEMPTS TO. WILL SPIN ON WASH CYCLE.
    Genius:
  • 3,422 Answers
HI,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Sep 13, 2008
  • Priya darshan Sep 13, 2008
    If your washer won't drain, check these:
    It spins, but doesn't pump
    It doesn't spin or pump
    It pumps, but the water returns
    If
    your washer spins but doesn't pump the water out, the drain line is
    probably clogged. In many washers, a small sock or other piece of
    clothing can get between the clothes tub and the outer tub that holds
    the water. If the clothing gets between the tubs, it may then get into
    the drain hose that's attached to the pump--or even into the pump
    itself. If it's in the pump, you need to remove the hoses from the pump
    and pull the item out.
    To remove the sock from the outer tub
    port, open the washer's main access panel and remove the large-diameter
    rubber hose that connects the pump to the bottom of the outer tub.
    Then, using needle-nose pliers, try to grab and remove the clothing
    through the port.
    Sometimes you can't remove the stuck
    clothing from below. Then you have to remove the agitator, top of the
    outer drum shield, and inner clothes tub. This isn't easy to do--and
    you may need special tools--so you might be happier getting a qualified
    appliance repair technician to do the job.
    If the drain line
    isn't plugged, the problem may be with your pump. Even if the pump
    appears to be turning, the internal impeller may be broken. If so, you
    need to replace the pump.
    If
    your washer doesn't spin or pump water out but the motor is running,
    your washer probably has a frozen pump pulley. If so, you need to
    replace the pump. To check the pulley, remove the pump from the washer
    If
    the water that pumps out of the machine goes back into the machine
    after the spin cycle, your washer may be siphoning the water from a
    laundry tub that has a slow drain, back into the washer. The usual
    remedy for this is to improve the draining of the laundry tub. (Is
    something stuck in the drain?) Also, check for these problems:
    • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
    • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
My kenmore model #110.42722200 washes but won't drain or go into spin cycle,it just makes a clicking noise.
this is caused by a faulty drain pump or broken lid switch tap the pump if it goes then replace it
Dec 26, 2015 | Kenmore Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Hi I have a Whirlpool 6th Sense Washing Machine - AWM8143. I is washing and spinning perfectly well and there are no error codes. However when it spins the machine makes a grating squeaking noise that is...
hi,
looks like there is some friction between the main and outer tub of your machine. there is generally a mechanism for smooth spinning of the machine in good rpms for wash-spin cycle. this could be because of rust formation, or mud collection. please refer your manual and remove the 3 screws behind the lower front plastic cover, and look for rust formation. scrape the rust and try spinning again.
cheers
Jul 26, 2009 | Washing Machines
Washing Machines Logo
74 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
