Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Thanks! Hi Thanks for the quick response. My wife has just told me that it is not a kitchenaid but rather a Bosch dishwasher. Does it change the solution? I also found this http://www.applianceaid.com/boschDW.html#fill suggesting that perhaps there is something clogged in the water drain (although there is no water in my dishwasher... Thanks Zahi
  • bendavid Sep 13, 2008
    Thanks! I solved the problem using the solution in, at the bottom of the page: http://www.applianceblog.com/mainforums/...
    I just used some paper to drain a bit of water from below of the dishwasher - the overfill float was stuck aparently - thanks!!!
    Thanks
    Zahi
    Sergeant:
  • 409 Answers
It changes it a bit for me as bosch and kitchenaid have quite a different design but they operate on the same principle.
can you supply me with the full model #?
you could have something caught in the drain pump.
Posted on Sep 13, 2008
  • Carmen Mikulic Sep 13, 2008
    Hi Zahi,
    You are welcome! Glad that I could be of help!
    Don't forget to vote for me!
Kitchenaid dishwasher is not cleaning the dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 30, 2011 | KitchenAid Dishwashers
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
I'm making myself crazy! I'm trying to decide if
Me... I would go for the Kenmore... who in their right mind wants to clean that **** out of a filter anyway??? Not me and I KNOW my wife would make ME do it......I mean GEEEEZZZ she don't even like cleaning the sink strainer basket!!!
Quiet is relative and the Kenmore is not going to be that noisey. Parts will be more readily available for the Kenmore if you need them...and I'm betting you will more than 5-7 years from that Kenmore anyway...
NAWH... you won't drive me crazy.. I do the same stuff before I buy a major appliance also!!!
I DO drive my wife crazy though!!!
Heatman101
Jan 19, 2010 | Dishwashers
My Kitchenaid dishwasher failed to drain. Is there a way to fix this without calling in a repair person?
Check underneath and disconnect the drain hose that leads into the pump to see if there is something blocking it.  I had a similar problem and the technician found a cherry pit that was blocking the hose.  He told my wife that it was a common problem and showed her where to check so we could do it ourselves if it happened again.  We have not had to.
May 19, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
More info on my dishwasher will not start
hi there,
thanks for the info. you are correct it's the touchpad. you can get one at www.reliableparts.com
let me know if can be of more help.
Sep 28, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Jan 17, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
138 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
