Question about Konica Minolta DiMAGE G400 Digital Camera
Lens will not retract
Hi i have a g400 the lens does not retract when i close the lens cover, instead it bleeps and the message "system error MFOOC" appears on the screen
  • 3 more comments
  • Anonymous Nov 06, 2007
    I have the same issue with the lens not retracting, and the same System Error (MF00C) message. The solution that you propose is not working. Any other (new) solutions?
  • Anonymous Nov 07, 2007
    I have the same problem, I have tried to push the lens cover carefully back in but it will not move, Please help?
    Regards,
    Karen
  • mladja Dec 23, 2007
    lens will auto close after a few minutes so the lens is ok but it will not close when the cover is puled to turn it off. Any tips about it becouse it may be a mechanical error. :(
  • clbish Apr 22, 2008
    Lens on my Minolta G400 was out and would not retract when lid was pushed towards lens. I read the solution and I pushed the lens back in but it stays in and the same symptoms occur when the cover is opened, it beeps and the error message mfooc shows up then the camera shuts down. Whats next?
  • tatttiana2 Jun 14, 2008
    I have exactly the same problem as garry! Don't know what to do!?!!! Any ideas?
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
Posted on Oct 23, 2008
  • 215 Answers
This is just another Lens Error Konica style. You can try the following but please be gentle....... Put a bit of force on the focusing lens whilst pushing the sliding door to help the lens back into the camera casing. That's the reason the sliding mechanism won't work. The lense is stuck and if you force it back in, the sliding mechanism will work again. The only other solution is that you sent their cameras, under warranty, back to, NOT Konica-Minolta, but now SONY. The service people will probably claim you dropped the camera and will refuse to honor the warranty. So take it into your own hands..literally! Good luck. By the way I have one of these little cameras and it suffered from the dreaded Sony CCD saga. It was replaced out of warranty for free. It's a darned nice camera except when it MF00C's up :-) BMW
Posted on May 27, 2006
Apprentice has it spot on. Having almost thrown the camera away, I got the lens to retract sufficiently to close the front then ,on opening it again I used two small screwdrivers on the lens front to persuade the lens to come out again fully. After which the camera works. The surrouding metal disc and a further disc came off during this operation, but are easily relocated. Unfortunately I have since lost the outside metal disc - the camera still functions - but if anyone has a spare disc due to de-commissioning, then please contact me!
Posted on Nov 03, 2008
Just solved this problem on my Dimage G530. An earlier time the lens (inner part) was cocked to one side after a small drop. Pulling it back straight, out of the outer part, fixed it and the lens closed.
Then just this past trip, the lens was not retracting with the MF00C error and the lens looked straight. It had opened in a pocket and gotten bumped. I had even taken the case off but that did not offer any insight into fixing the problem. (They certainly cram a lot into the case). I was about to give up and just buy a new camera or was going to inquire at vistek to see how much it would cost to have it looked at this Saturday because I really like the camera. Anyway, to make a long story short. I decided to pull hard on the inner part to pull it out - basically try to cock it to one side then the other. The lens popped out to it normal position and now everything works fine. So it appears that if bumped the lens goes to a lock position to prevent any damage to the drive mechanism.
Hope this helps someone else with this problem.
Posted on Jan 23, 2008
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
What is system error MFOOC
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 28, 2010 | Konica Minolta DiMAGE G400 Digital Camera
Lens will not protrude on opening
Hi, I had the same problem.I fixed it doing the same thing as for the lens not retracting. Hop ethis helps.
Good luck.
Paul
Dec 29, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Minolta dimage g400 camera...cannot get the lens to close
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Oct 20, 2009 | Konica Minolta DiMAGE G400 Digital Camera
System error
This eroor usually comes due to faulty sliding mechanism.Put a bit of force on the focussing lense to push it back into camera casing. That's the reason the sliding mechanism won't work. The lense is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.
Or else try out this method
Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Hope this will work for others too.
Aug 28, 2009 | Konica Minolta DiMAGE G400 Digital Camera
System Error
I had the same problem. It was because the lens had just begun to retract and then jammed. I tried pushing back it in to no avail. I was considering it was time for a new camara anyway. Hoping to get a little more life out of it, with nothing to lose I was about to take it apart to see if I could clean out any obstruction as other posts had reccommended. Before I did that, I let my Mr. Goodwrench cousin take a look at it. Instead of trying to force the lens back in, he pulled it out. Apparently the slight play in the lens allowed him to do so and whatever was jamming the lens from retracting must have fallen out. Suddenly, the lens retracted and the camara is working fine. So before you throw the camara away or take it apart, try pulling out on the lens housing. You may also have to move it slightly back and forth while pulling out to get whatever is jamming the lens to move out and away releasing the lens to retract again.
Oct 25, 2008 | Nikon Coolpix 775 Digital Camera
Error system MFOOC
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 08, 2008 | Konica Minolta DiMAGE G530 Digital Camera
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Aug 03, 2008 | Fuji FinePix F20 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Konica Minolta DiMAGE G400 Digital Camera Logo
1,132 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
