Question about Maytag MSD2656G Side by Side Refrigerator
Water and ice not depsensing...light "stuck on"
  • 3 Answers
Most likely the problem is a bad dispenser control board. For a more accurate answer, I would need the model and serial number of your refrigerator. You can find the model number in the fresh food compartment in the top right or in the upper section.
Post it back
techgirl26
Posted on Sep 13, 2008
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
Water reasavore over flowes
Replacing Manitowoc water level probe and Ice Thickness
Feb 12, 2013 | Manitowoc SY0454A S Series Ice Maker...
Not making ice
check for a stuck float switch. located near the water pump. Usually white plastic with a tube on top and a black boot at the bottom. Tap on it lightly while unit is filling with water. If that works, you need to disasseble and clean.
Sep 30, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My GE GSL25JFPEBS side by side refrigerator stopped making ice. The green power light blinks indicating ice being stuck, but once the ice is removed from the mould, the problem starts all over again. It...
i am wondering if ice is constantly getting stuck or are the cubes smaller that the size of the mold? if that is the case have you tried replacing the water filter. The typically reason ice gets stuck in the mold is because the individual cubes (usually 7 or 8 per mold) are too small,the leading cause of that is not enough water in the mold
Also is water dispensing through the door with good pressure, if no replace filter but first check the pressure of the incoming water from house plumbing
Jul 29, 2011 | GE Refrigerators
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Softner will not dispense
not draining from compartment is usually caused by a blockage it compartmnet, try pooring boiling water into the compartment, this will usually resolve problem
Dec 08, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MSD2656G Side by Side Refrigerator Logo
60 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
