Question about Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
I can not get a TV signal to work with the Toshiba through coax.
I just got a Toshiba 27 inch TV/DVD/VCR combo. The DVD and VCR works great but I can not get a TV signal through the Coax. Since I have Satilite and this is my second tv I should just need to put it on Channle 60. I also tried the second channel that Direct tv lets you use. Any advise would be great. Also I do not have the remote for this TV.
  • Anonymous Dec 14, 2007
    trying to set up an"ONE FOR ALL" remote to work a 32 in Toshiba TV.
    cannot find the right code for TV
    President:
  • 3,130 Answers
Bill24 sorry to be the one to tell ya but you need to go into setup on the tv to setup the channels in the menu and the memory and the only way is to do it with an original remote. BUT your in LUCK. http://remotes.com or 1-800- remotes has the remote you need for $27.38 + shipping. Good Luck
Posted on May 27, 2006
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
On my combo tv/vcr/dvd the vcr and dvd do not work is there a way to hook up an external dvd player
DVD's dont have coax output so you can use your RCA output (yellow,red and white) and hook to the input of your TV you just gotta select the input its on(i.e. Video1)
Jun 28, 2009 | Samsung DynaFlat CXM2785TP 27 in....
Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Feb 03, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
DVD PLAYER WON'T OPEN
Do you see the open close icon ont the screen? Do you hear any motors running? Most common problem for this is the mech jumps time
Jun 17, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
DVD Operation
37inch av500ui hdlcd tv can't get dvd to ply. keep getting no signal.
Jun 11, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Memorex television is not working with my new Phillips DVD/VCR combo
depending on how you hooked it up; if thru coax cable the you have to use channel 3 or 4 on the tv to use Philips. If you are connecting with video and audio cables then you have to select a/v input on tv to use.
May 08, 2008 | Memorex MT2271 27" TV
20 INCH TOSHIBA DVD VCR COMBO, DVD KEEPS READING BUT NEVER DOES
I was having the same issue and I've been to several video stores to rent DVDs and 2 out of 3 rentals have the same affect where it is just 'reading' but even worse, it would play fine and then freeze up during the movie- very frustrating. Now, after 3 years of owning it, it died today. They just don't make them the way they used to :(
Apr 01, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Toshiba MW27FN1 27 in. TV/VCR/DVD Combo Logo
153 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
