Question about Kenwood KDC-MP235 CD Player
No auxiliary source option kdc-mp 235
I recently had to change out my battery and now auxiliary is no longer an option as a source. Can't run my Zune any longer thru the stereo.
  • 1 more comment
  • brandon531 Oct 01, 2008
    i have the same problem- cannot access the front AUX port on my kenwood. i get "tuner" and "standby" as input options.
  • jimg613 Oct 13, 2008
    Ya i have the same problem were i get tuner and standby i just went out and bought a input so i could play my ipod and not cds and now im out $20 because this messed up thing
  • Anonymous May 03, 2009
    Ditto same problem here
  • 3 Answers
I have a kdc 135 and i had the same problem. you have to go to standby mode, then hold down the menu button until MENU appears. then toggle up or down with the button on the right and it will say aux. then toggle left or right to turn aux on/off and then after that when you hit source it will come up as an option.
Posted on May 03, 2009
I have a kenwood kdc-mp235 unit and I bought a cable to hook smart phone to auxiliary port, I can play a cd or tunerbut no auxiliary! How do I fix this, I push src button but I get no auxiliary selection
You have to have the deck in "standby" mode before entering the settings menu. Press the source button until Standby comes up, then press and hold the menu button. Use the 4-way switch to scroll through the menu options until you get to AUX, then press the switch to the right to turn it on.
I got this from yahoo, click here to view.
Hope it helps.
May 29, 2011 | Kenwood Car Audio & Video
I have a Kenwood KDC-X817 CD receiver and im trying to be able to use my ipod with it. It says on some on the online manuals that you can accept input from an auxiliary source When used with an optional...
I have the same problem with the KDC-x817 and i tried following these steps, but when I am in the menu and scrolling through the options, I don't see anything that says AUX off. Am i missing something??
Apr 25, 2011 | Kenwood KDC-X817 CD Player
I bought a used car and it already had a kenwood kdc-x890 installed. my question is when i plug my zune or even just a mp3 player into the usb port it responds with [n/a data].
The KDC-X890 will play MP3s that are stored on a USB mass storage device, such as a USB thumb drive. It won't play music from another MP3 player such as a Zune through the USB port, but you could plug your MP3 player into the auxiliary jack.
Mar 04, 2011 | Kenwood KDC-X890 CD Player
Connecting Zune to Ipod hookup in new Sentra
The radio doesn't support the Microsoft zune your only option is to use the 3.5 head phone jack or buy an iPod or find a fm modulation adapter you can still fine them on eBay
Nov 26, 2017 | Microsoft Zune JS8-00001 Digital Media...
I CANT FIND THE AUX INPUT SORCE ON MY KDC-MP435U CD PLAYER
You need to go into the menu and actually switch the aux to on. If you have your owners manual it will tell you how to turn it on. It is under the menu option "built in auxiliary input setting" If you do not have the manual i have a link to it for you. Hope this helps.
http://inform3.kenwoodusa.com/manuals/KDC-MP435U.pdf
Mar 03, 2009 | Kenwood KDC-MP435U CD Player
Please help!!!!!!!!!!!!!!!!!!!!!!1
My Zune 30 is frozen. What should I do?
Follow these steps:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required—you can go back to using your Zune!
Dec 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Kenwood KDC - MP 235
I would also check the speaker outputs from the deck. If any of the speaker outputs are touching any metal on the vehicle, it could give that message.
Dec 08, 2008 | iLO XM-MP3-CD Car Stereo
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better...
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Kenwood Car Audio & Video
Clock display on KDC-MP235
I've found the manual to be inaccurate as far as setting the clock. To display the clock, hold down the right knob, then choose Freq or Clock. Push again to set. Easy.
To set the clock, push the source button until you're in standby mode. Hold the left knob down (volume ctrl) until menu comes up. Either push the left knob OR move the right up or down (can't remember which) until you see Clk Adj. Push the vol ctrl knob (I think). Then, the knob on the right goes left right for minutes/hours, and up/down for the other. I believe you can push the vol knob then once its set.
Feb 16, 2008 | Kenwood KDC-MP235 CD Player
Switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Nov 12, 2007 | Kenwood eXcelon KDC-X579 CD Player
Kenwood KDC-MP235 CD Player Logo
926 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
