Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Change the belt in my kenmore power-mate 120 amps...how to open it to get to where the belt is???
Don't worry...I dont expect any help...just a shot.
have a good day.
HELLO, JUST REPLACED THE BELT ON OUR'S. FIRST TAKE LITE LENSE OFF THERE WILL BE 2 SCREWS, REMOVE. THEN FLIP OVER POWER MITEON EACH SIDE PRY WITH 2 SCREW DRIVERS WHERE THE ARROWS ARE TO SEPERATE & THERE IT IS THE BELT. MIKE
Posted on Jan 23, 2009
Pop off lite cover unscrew two screws ,pull off rubber cover around base push screwdriver in slots on sides pop off base
Posted on Sep 21, 2008
    President:
  • 1,462 Answers
I've never met a cannister vacuum with a belt yet. belts only used on uprights to drive the brush roll
Posted on Sep 14, 2008
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
Kenmore model 116 58015700 power mate beater bar stops working
Just pulled mine apart and the bearing on the belt side is toast. In the past five years I have had several items fail due to less then optimal bearings. Including a transmission in a Vibe and a front load washing machine.
Mar 30, 2013 | Kenmore Vacuums
The power head of my 1165581590C Kenmore Power mate Whispertone 12 amp vacuum won't open. It is an older model and it desparately needs a clean!
I am not 100% sure of the model number but most of their powerheads come apart quite easily if you know how. There is a light lens cover on the top of your powerhead. On each side of this cover there is a little clip that holds it in place. You can usually see that spot by simply taking your thumb and pushing the light cover to one side or the other. Place a small flat head screwdriver in that slot and gently pry upward.
Once that cover is off, you will see two screws. Remove those two screws. Now simply grab each side of the cover towards the bottom and back of the nozzle and pull out. This should release it from the base. It will lift from forward from back to front..
Reassembly is pretty easy. Just reverse the instructions.
Let me know if this helps.
Dec 30, 2012 | Vacuums
How do I get to the belt for replacement?
Go to Google or Yahoo and type in "kenmore powermate belt", then select what ever store you want to order it from or if local store, go there and pick it up. I prefer online ordering as long as shipping is cheap, that way it comes right to the house and I don't spend time running around looking for it. There are even "how to" instructions online.
Oct 08, 2012 | Kenmore Vacuums
I own a Kenmore vacuum cleaner model # 116. 56550990C. I have lost the instructions to replace the belt in the Power Mate. The Power Mate beater just stopped working and I need instructions on how to...
If unit beater has stopped working it is either the motor, the power connection to beater or the belt that powers the roller. Which is it?
See if you can download the manual from the mfg or google for it.
Sep 05, 2017 | Kenmore 25614 / 25615 Progressive Bagged...
Owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at) govacuum.com.
If this helped you, please click the Helpful button below.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Kenmore Vacuums
Kenmore vacuum model 25614 power mate will not reset
What you see from the outside is usually a pop up button which sits on top of the actual internal switch remove the lid of the power mate as though you are cleaning the brush roll or changing the belt. Then test the reset internally. Post back to advise .
Sep 19, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore whispertone model 11620412003
I am getting suction to the power mate, but the mate doesn't
work. The belt seem fine, but the light and beater doesen.t
go on. Tried the reset - no result. Thanks
Dec 29, 2007 | Vacuums
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
3,129 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
