Question about Sanyo DS31520 31" TV
Sound the sound turns off at different intervals. i have to hit the off button to get the sound back. after awhile the sound goes off and hitting the off button doesn't work and i have to unplug the television. this happens after the television has been on for a few hours. i also have a problem turning off the television. i have to hit the off button several times and then hold it down for the television to stay off.
    President:
  • 3,130 Answers
Sounds like you have a bad ground or cracked board or even several cold solser connections on or around your microprocessor IC. Could even be a bunch of cold connection , some around the sound output ic But my feelings are they are all around the Micro. Your gonna need to be goo with a soldering iron and a plasit pick tool to find the area ao if you have no experience in electronic troubleshooting i would take the set into a pro. Good Luck
Posted on May 27, 2006
SOURCE:
Sometimes my clarion stereo won't turn on and it needs a couple of tries to hit the power button on
you need to contact clarion and tell them the problem sounds like you have a defective stereo and they should replace it under warranty
Mar 24, 2014 | Clarion NX602 In-Dash Car GPS Navigation
Main board green light blinking at 5 flashing intervals
researched your problem a little, it sounds like a burnt out board. It doesn't look too good for parts either. google your symptoms and you will see a few hits on your exact issue
Jan 29, 2010 | Gateway GTW-P42M303 42 in. Plasma...
My heater/ac fan dont work then when going down the road hit a bump it comes on for about 5 minutes the goes out also if you turn the steering wheel to the right on a curvy road it will come on turn back...
This sounds like a loose connection to the motor itself. My truck has been doing that lately and I finally figured out the problem only when I starting digging under the dash while the heater was going.
When you turn left or right, the steering column must be tugging on the wiring, and when you hit a bump it's just enough to jar the connection loose. Check where the plug goes directly into the motor...most likely it's under the dash on the passenger side, or on the firewall on the same side, but in the engine compartment. It could also be that your steering column has worn the coating off of the wire and it is shorting out every once in awhile when the exposed wire hits metal.
Nov 08, 2009 | 1995 Buick LeSabre
Need codes for LXI tv/vcr combo
you need to hit code search and hold it in untill the light lights up and then you hit button that says tv and then keep hitting power untill tv goes off but dont hit the button after the tv goes if you do you will have to restart and after the tv goes off then hit enter and then turn the tv back on and then you can control the tv.
Jun 15, 2009 | One For All URC-3021 Remote Control
E studio 202L copier won't copy unless interrupt button is lit
Sounds as if when your hitting the interupt button you are interupting a copy job the machine "thinks" it is doing, try clearing the print que on the copier.
Apr 13, 2009 | Toshiba Estudio 200L Copier
Screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Mar 23, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Looses video
There are so many thing that can cause this to happen. If you answer some questions we can narrow it down some. 1) when the picture goes black if you hit the menu button on the mitsubishi remote or on the front of the tv itself does the menu show up? 2) After it goes dark how do you get it back? do you turn it off and let it sit for awhile or can you turn it off and then right back on to get a picture? 3) what is the model number? this can be found on the back of the set. If you can answer these questions we can go forward.
Thanks!
Tim Nolan
Sep 11, 2008 | Mitsubishi WS-55807 TV
Turning off PIP on KP-61v45
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Sanyo DS31520 31" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
