Question about Empire DV-215 Direct Vent Natural Gas Heater
Installing a boiler
Was wondering if you could help me. i had an outdoor wood boiler installed and now i can't get it to work with my 1990 miller gas furnace. i am using two seperate thermostats so if the boiler goes out the gas furnace will turn on. i would appreciate any help you can give me. thank you sweetuper
  • 1,420 Answers
Set the Miller to turn on at 7-10 degrees lower than your wood boiler. Make sure the Miler works by turning up the t-stat 10 degrees higher than room temperature first.
Posted on Sep 19, 2008
Loud vibration
1) What brand and type water heater? Gas or electric? Tank or tankless? Or boiler? Solar assisted? Indirect? Wood-burning? Oil-fired? etc?
2) How old is heater? Is this a new installation? Or installation that worked before and vibration is something new.
3) Or are you talking about a washing machine instead of water heater? Or hair dryer? Or GMC truck?
4) Add a comment and give more exact information from label located on side of unit, for possible assistance.
Feb 18, 2013 | Water Heaters
Tip
How to Hookup Your Outdoor Wood Boiler
You just bought or a thinking of buying an <span style="font-weight: bold;">outdoor wood boiler.</span> How do you integrate that boiler into your existing <span style="font-weight: bold;">home heating system</span>? The guy selling you the boiler wants the sale and tells you that hooking it into your system is very simple.<br /><br /><span style="font-weight: bold;">Outdoor wood boilers </span>come in many shapes and sizes. For the most part bigger is better for these things. The next thing you need to consider is whether the <span style="font-weight: bold;">boiler is an open or closed system</span>. It does make a difference in the way it gets hooked up. <span style="font-weight: bold;">Closed systems</span> can be hooked right up to your <span style="font-weight: bold;">existing boiler system </span>in a <span style="font-weight: bold;">primary secondary configuration</span>. This means that the wood boiler circulates to two tees in your home system and the home system circulates the water through the home. The two waters mix through the tees.<br /><br />If your wood boiler is an <span style="font-weight: bold;">open system</span> then you need to install a <span style="font-weight: bold;">stainless steel flat plate heat exchanger </span>to divide the two waters. The hookup of the <span style="font-weight: bold;">heat exchanger</span> is not that hard if you follow the instructions properly. This heat exchanger is very effect in<span style="font-weight: bold;"> transferring the heat</span> from the wood boiler to the inside heating system. It also keeps the water of the<span style="font-weight: bold;"> inside system pressurized and isolated.</span><br /><br />If you are installing your outdoor furnace to a <span style="font-weight: bold;">hot air heating system</span> then you need to <span style="font-weight: bold;">buy a coil</span> similar to your car radiator to install in the plenum on the supply side of your <span style="font-weight: bold;">existing hot air furnace</span>. To this coil you will <span style="font-weight: bold;">hookup the water pipes from the outdoor boiler</span>. The water running through the coil will heat it up so that the air going through from the <span style="font-weight: bold;">hot air furnace </span>will be warmed. The water hookup for this style of heat is very simple, but the <span style="font-weight: bold;">electrical hookup of the blower, pump, and circulator </span>may not be as simple. You may need someone with a good electrical knowledge to make everything happen in the right sequence.<br /><br /><span style="font-weight: bold;">Outdoor wood boilers can heat your home effectively </span>if they are <span style="font-weight: bold;">installed to your existing heating system properly</span>. If they are installed properly you will notice no difference in the heating of your home. It will be <span style="font-weight: bold;">warm and comfortable.</span> Make sue that you do your research properly before trying to <span style="font-weight: bold;">install your outdoor wood boiler.</span>
on Feb 21, 2011 | Heating & Cooling
Tip
Gas Boiler Condensing Best Features
Condensing boilers are the most efficient way to heat that there is today. The BTU’s that they wring out of the fuel put into them is the best of anything available today. Not only do they burn their fuel very well, they also have technologies built into them to help give then the highest efficiency possible on any given day.
Condensing gas boilers have been on the market for about twenty years now. The early boilers were noisy and very heavy. Today’s condensing boilers are not even remotely the same as their predecessors. There have been many improvements that make these boilers lighter, safer, and more reliable than ever.
Many of today’s condensing gas boilers are controlled by a computerized control that gives many options and features to customize your boiler to the type of system that it is being installed in. Not only does the control monitor the boiler, but it can be setup to control the whole heating system as well. This gives the added benefit of fewer controls and the saving of space. Circulator pumps, mixing controls, and injection pumps can all be controlled by the boiler control.
These technologies are things like sensors to make sure that they are running at the highest combustion efficiency possible or they will shut down. Outdoor reset controls will vary the water temperatures to make sure that the water temperature is only being heated as hot as is needed to make your house warm at any given outdoor temperature.
Sensors also monitor the supply and return water temperatures constantly to shut down the boiler if the boiler senses any unsafe conditions.
These boilers are so good that even if you fire the boiler before filling it with water, the boiler will shut off before it is damaged.
When looking at the boilers on the market today take into consideration all of the benefits of that the newer high efficiency boiler have to offer. High efficiency is really great, but there is so much more to them. The ease of installation because of the light weight of new condensing technology, the versatility of the controls that are incorporated into these boilers, and the outdoor reset technology that will save you fuel and make you much more comfortable.
http://www.fixya.com/support/r3706297-gas_condensing_boiler_high_efficiency
http://www.fixya.com/support/r3583943-condensing_gas_boilers__the_best_radiant
http://www.fixya.com/support/r3597748-the_extra_benefit_of_a_modulating_boiler
on Dec 24, 2009 | Heating & Cooling
I have a Utica boiler pilot is on. instaled in 1990
Check the gas valve on the boiler. See if it is on the "pilot" setting. Sounds like it is....if so, turn to "on"
Nov 09, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Tip
The extra benefit of a Modulating Boiler
You're looking to install a new hot water boiler or replace your existing boiler. You come across something called a "modulating" boiler. You wonder what on earth that means. I will attempt to explain some of the features of a modulating boiler.
How nice would it be if you could have your boiler make just enough heat to keep your house warm and nothing more? Your thermostat tells your boiler that you need heat in the house. The boiler starts up and heats the water that runs through the pipes to heat your house. The water does not heat up to temperatures that are more than just warm. But you notice that the temperature in your house is staying right where you want it to be.
This boiler is no ordinary boiler. It knows what the temperature is outside and varies your water temperature to make just the heat needed to keep you comfortable. The modulating boiler also runs much more then a normal boiler would but you can see by your gas bill that you are getting great efficiency from this thing.
The feature that makes this wonder so great is that it has the ability to vary the fire that heats the water up and down so that the water temperature stays precisely where the computer brain in the boiler wants it to be. This temperature is figured by measuring the outdoor temperature and changing the water temperature based on that. The colder the weather is outside, the hotter the water is going through your system.
With a system like this you will notice that your heat will run longer and still not cost anymore money. This makes you more comfortable. The modulating boiler will give you just enough heat to keep you warm without wasting much of the heat that a normal boiler would. This type of furnace will give you the most efficient heating possible on any given day.
Before buying a new heating system or replacing your old hot water boiler make sure that you check into a system that will modulate the fire and also vary your heating water temperatures according to the outdoor temperatures. This will save you money and give you a very comfortable heating system.
on Dec 08, 2009 | Heating & Cooling
Tip
Boiler Energy Saving Controls They can save You Money
I was recently emailed a question by a fellow that wanted to know if an outdoor reset control would help him cut fuel oil costs for a seasonal home in that was only used occasionally in the winter. The short answer is yes, however there may be a better control for him and his particular circumstance.
Energy saving devices are great things in many ways and they usually do save you money. The problem is that you need to use the right device for the job that you want to do. Using the right control to do the job you need is the question that needs to be answered. Just because you spend a lot of money on a control it does not mean that you will save a lot of money.
What kind of fuel are you burning? What type of boiler do you have and at what water temperatures can it be run at? These are a few of the critical questions you must consider.
If you have a condensing gas boiler and have a heating system that will heat at fairly low water temperatures for most of the season then an outdoor reset control will be worth installing. If you have an oil boiler that needs to run at hotter water temperatures to prevent condensation then you may want to use a different control.
Oil boilers often run a hot fire and usually are not piped in such a way as to get the heat away from the boiler as fast as it is produced. Because of this the boiler will be cycling many times an hour. This cycling will decrease the efficiency of the boiler and cost you money.
By installing a Beckett HeatManger on your oil fire hot water boiler you will make the run times longer and increase your efficiency. The Beckett HeatManager will smooth out the cycling and get you the comfort and efficiency that you want for much less money than many of the outdoor reset controllers. In many cases you will save the price of the control in a month. The best part is that many average do it yourself persons can install this control themselves!
Using the right tool to do the job you want will save you fuel, time, and money. Make sure that you find the right product to install before you just start throwing money at a problem.
on Dec 06, 2009 | Heating & Cooling
Aprilaire
Commonly outdoor wood boilers use a hot water coil mounted in the ductwork above your furnace. In this application the Ruud furnace is still using its blower assembly to circulate the warm air from the boiler to your home. If this is the case. Have your heating guy install a #50 relay on the furnaces blower motor to activate your much needed humidifier. If this is not the case and your Ruud furnace is totally independent of the boiler. Still install the #50 relay in the furnace and manualy activate the fan only feature on your thermostat.
Good luck
HVAC Teacher
Feb 21, 2009 | Aprilaire 600 Humidifier
Smell of gas with new boiler when on?
If you had it professionally installed i would call the company who installed it to come bac and fix problem...If you installed then i would check all the gas connections for tightness
Feb 02, 2009 | Heating & Cooling
Tip
How to Hookup Your Outdoor Wood Boiler to Your Existing Heating System
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You just bought or a thinking of buying an outdoor wood boiler. How do you integrate that boiler into your existing home heating system? The guy selling you the boiler wants the sale and tells you that hooking it into your system is very simple.
Outdoor wood boilers come in many shapes and sizes. For the most part bigger is better for these things. The next thing you need to consider is whether the boiler is open or closed. It does make a difference in the way it gets hooked up. Closed systems can be hooked right up to your existing boiler system in a primary secondary configuration. This means that the wood boiler circulates to two tees in your home system and the home system circulates the water through the home. The two waters mix through the tees.
If your wood boiler is an open system then you need to install a stainless steel flat plate heat exchanger to divide the two waters. The hookup of the heat exchanger is not that hard if you follow the instructions properly. This heat exchanger is very effect in transferring the heat from the wood boiler to the inside heating system. It also keeps the water of the inside system pressurized and isolated.
If you are installing your outdoor furnace to a hot air heating system then you need to buy a coil similar to your car radiator to install in the plenum on the supply side of your existing hot air furnace. To this coil you will hookup the water pipes from the outdoor boiler. The water running through the coil will heat it up so that the air going through from the hot air furnace will be warmed. The water hookup for this style of heat is very simple, but the electrical hookup of the blower, pump, and circulator may not be as simple. You may need someone with a good electrical knowledge to make everything happen in the right sequence.
Outdoor wood boilers can heat your home effectively if they are installed to your existing heating system properly. If they are installed properly you will notice no difference in the heating of your home. It will be warm and comfortable. Make sue that you do your research properly before trying to install your outdoor wood boiler.
on Dec 03, 2009 | Heating & Cooling
Empire DV-215 Direct Vent Natural Gas Heater Logo
239 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
