Question about VeriFone 355 Thermal Printer
Needs new ink ribbon
Is there an address I can contact to get a manual to show me how to put a new ink cartridge or ribbon in a 355 and to tell me where I can purchase a new ribbon or cartridge? My print is getting almost too light to read. Thank you. Jim M
2 Suggested Answers
  • 1027 Answers
SOURCE: Printer won't print.
Does it use thermal paper? Did you put plain paper in it?
Posted on Apr 07, 2010
Printer won't print - error 1203
Tell me how long the printer sat with empty cartridges? More than 30 days?
You may want to deploy this trick: take new ink cartridges out, put them to the side. take the hair dryer and for 2-3 min, blow hot air around the area and clean up the ink with alcohol swabs until clean! Also clean with alcohol, the contact points and surrounding area. Reinsert the ink and try and see if the printer recognizes new ink.
May 07, 2014 | Lexmark P4350 All-In-One InkJet Printer
I have a Canon MP460 printer and its telling me that it doesn't recognize my ink cartridge. I have even brought new ones but still tells me that it don't recognize ink cartridge. I have cleaned contacts...
U must be using PG40, CL41...
Well.... if you put brand new one, (not the compatible one) and see the same problem... that's something needs to be cared of by A/S center.
However, if you put in the compatible or refilled cartridge (anther one), still u will c the same e5 error.
E5 errror is something can't be solved....
Apr 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
The red ink is not working.I put in a new cartridge still nothing .prior to this I refilled the old cartridge which for some reason leaked the red ink almost completely. I was told the nozzles and...
I am not sure about "injecting" the alcohol - but I would have agreed with external cleaning with it.
If all you have done has not produced a cyan (red), the your contact for that color is dirty/oxidized/broken. That ribbon cable is pretty strong, but the contacts that make with the cartridge have been known to become dirty. If a q-tip with alcohol on it rubbed over the contacts that make with the cartridge don't correct the problem, check the ribbon cable for damage - and replace it (or the printer) - probably cost about the same.
Let us know what you find, please. -Jim
Oct 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Tells me ink cartridges are empty, even after putting new ones in. please help
Hello there,
In this case you need to please remove the new cartridges and place the old one in back and check if they are getting detected then it clearly shows that the problem is with the new cartridges. If the same persists with the old one then try ckeaning the circuit portion which is on the cartridge and the printer. and then check for the same else carrier stall needs to be replaced. Thanks and all the best
Aug 08, 2009 | Lexmark P4350 All-In-One InkJet Printer
How do I put in new ink cartridge??
Get yourself a new ribbon Gen. Ribbon T-340 and a lift off Gen. Ribbon T-350 the lift off snaps onto the bottom of the ribbon and then both go on the typewriter there are two small tabs onthe ribbon cassette that go into notches on the front of the ribbon deck then the unit snaps down in the back held by the blue latch.
DickyO
Aug 04, 2008 | Lexmark Wheelwriter 1500 Typewriter
Cartridge erro
hi,
try to clean the printer contacts of the left.before you do that unplug the powercable first.used a cotton swab to clean the copper contact of the printer..after cleaning insert the ink cartridge..if the error is still occuring this is now an issue of the printer..the printer needs to be replaced/serviced...
Jul 17, 2008 | HP Officejet 6310 All-In-One InkJet...
VeriFone 355 Thermal Printer Logo
22 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
