Question about Maytag Washing Machines
My maytag ensignia washer has an electronic panel. We took the little basket out of the cold water line cleaned it and replaced it. Now the washer, in all cycles, will start to fill then stop and all the green lights on the panel will flash. What is wrong?
  • joysizemore Sep 14, 2008
    We did all of that and it is still doing the same thing.
  • 725 Answers
First I would check your water lines that they are on all the way and that you didn't switch the cold and the hot water line...if this doesn't work let me know we can go deeper into it....let me know
Posted on Sep 13, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 16, 2008
    Try a hard reset Unplug the washer for 30 sec plug in and try it... if this don't work send me you full model and we will help.
Will only pull water in if knob turned to hot
You will need to replace the "water inlet valve". The cold side is not allowing the cold water thru. Here is the part to order.
Jun 25, 2013 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Ensignia model MAV2757 AWW. The washer basket doesn't balance, even with a small load, and turns off due to the weight being unbalanced. The springs are there and oiled, the hardware...
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
Nov 14, 2017 | Maytag Ensignia MAV2757AWW Top Load Washer
The cold water just trickles into the machine, the hot water fills fine. I removed the hose from the wall and cleaned that filter. Is there another filter I can clean out?
Hello klj... Unscrew the cold hose from both ends and run a wire through the entire length to remove any blockage anywhere. Also check the connection locations looking for calcification of some kind. If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve. Joe
Thanks for choosing Fixya!
Dec 06, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Cold water doesn't shut off and keeps pumping into washer
Replace the water valve where the hoses connect to the washer.
Mar 24, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing Machines Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
