Question about Toshiba Satellite L20-S310TD Notebook
Toshiba L20 - screen appears dead?
When I switch the laptop on geen indicator flases once - nothing appears on the screen, fan for cpu comes on and stays on - nothing happens after this!
Wireless activity indicator is off, battery is fully charged
Hepl
  • sycspysycspy Dec 18, 2008
    I used my laptop bit torrent some software last night when i was sleeping. In the morning I found the laptop hang. I restarted and it appear dead...
    Scholar:
  • 135 Answers
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Posted on Sep 17, 2008
Hello, I have Toshiba Satellite M200 window Vista, I have a new problem after working for 10-15 mins my laptop is getting hang nothing visible on screen just blurred screen , when i switch off and start...
Your Toshiba could be overheating.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 06, 2011 | Computers & Internet
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 22, 2009 | Ultra Computers & Internet
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
Dell PC cant display image on the screen
it is the indicator that shows that some informations are read on your hard disk.there is nothing to be fear.screen comes after some time
Mar 12, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Toshiba M55-S1001
4 Beeps means there is a fault with the CPU.
It could be that the fan is faulty and needs replacing, or it coul be that the CPU is dead.
Unless you are technically mined enough to take the machine apart yourself, then your only course of action is to take it to a dealer for repair.
Aug 13, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
Jan 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Notebook not starting and screen remains blank.
this will be easer than you think.
first unplug power cord,pull out your battery and test it by pushing the button on the battery. It will be dead. leave it out. plug in power cord, nothing should work. test your power cord. if nothing than test lower on the cord it might be the plug in that plugs into the laptop. what happens is the battery get to low and the lappy goes into a safe mode . you will need a charged battery to get it to boot.
Dec 30, 2007 | Dell Inspiron 1100 Notebook
My Toshiba satellite L20 laptop has gone into hibernation mode and I cannot switch it on at all.
Try reseating the battery(Basically try taking out the battery for 10 secs then putting the battery in). The battery is located probably behind and under the laptop!! If that does not help, there could be something worse wrong with your laptop. When you plug it in does the indicator show that its plugged in? regards, babb
May 06, 2007 | Toshiba Satellite L20-S310TD Notebook
Toshiba Satellite L20-S310TD Notebook Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
