Question about Hitachi 27FX48B 27" TV
No Vertical Sweep
I have a Hitachi 27FX28B.. when I turn the television on the picture is fine, within 3-5 minutes though - the picture compresses to a thin vertical line across the middle of the screen (audio is fine). The television is 8 years old.. what is the problem and is it worth fixing?
    President:
  • 3,130 Answers
The verticle output iC or the b+ feed is going bad. To fix it your gonna need a multimeter and experience working with tv. Now to its worth??? do you like the set? Does it have all the fetures and fuctions that you liokeand how good is the picture? It shount cost ya more the 125 to 150 for this repair. Good Luck
Posted on May 27, 2006
Vertical hold problem
This is not a vertical sweep output problem. Check and replace all the supply filter capacitors at the secondary side power supply section to SMPS.
Sep 01, 2012 | Hitachi 60EX38B TV
There is no picture when turn on
If model is correct here, a few questions:
If you have sound or not?
if on screen display shows or not?
if power light goes off when set turned off?
The set is prone to a few odd issues as well as some common ones.
If you follow power cord inside (ought to go to board mounted on right side wall) there are at least 3 black power relays on that board that are known to stick either open or closed---tapping on them will sometimes cause them to function again for a while---ie if power light does not go out etc.
If you have sound the set will be likely turning off or blanking all three picture tubes for a reason= no vertical sweep or horizontal sweep as that would instantly burn a mark on all three tubes--check the possible relay issue and let me know answers to the questions I have asked above.
I have worked on a lot of this model set and am familiar with it.
May 21, 2012 | Hitachi 53UDX10B 53" Rear Projection...
My screen goes blank after about 30 seconds or so, any ideas?
about the only common issue (if model listed here is correct) is bad solder connections at the vertical output IC.
Usually in this case jarring the set will cause it to try to open and allow the picture--if no vertical sweep (pic top to bottom) set will blank all 3 tubes to prevent an instant burn mark on them.
Apr 19, 2012 | Hitachi 50EX20B 50" Rear Projection...
My HITACHI 51SWX20B was working fine before dinner. It was turned off for about an hour or so and when we turn it back on the picture was black and neither of the remotes worked (they wont' even turn the...
If no remote function, unplug set for a minute and plug back in; if not the problem something is wrong in either power supply or sweep circuit of set--
DOES POWER LIGHT COME ON AND STAY ON?
sd tech
Sep 20, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 42EDT41A Turn On with white and yellow vertical lines
you have to replace the vertical sweep IC and check the voltage across its VCC. If you cant understand tech words, better visit the service center.
Jul 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Bad picture on a Hitachi 53"
The problem is in the vertical sweep ckt. and is heat related. Would need to be repaired by a tech.
Electrode
Feb 28, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
60sx12b/13k black screen
Hi, you have some poor solder connections on the sweep board, this is an inexpensive fix for any tech to do, get it soldered and enjoy, good luck & Happy Holidays
Nov 28, 2007 | Hitachi 60SX12B/13K 60" Rear Projection...
Jumping picture for a few minutes
theres a bad capacitor off the sweep power supply or possibly in the main power supply. Most likly though it would be where i mentioned first. There are no user serviceable parts inside this set Unless your a repair person so best thing for you to do is call in a pro to assist you in this repair. Good Luck
May 31, 2006 | Toshiba 50H72 50" Rear Projection...
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
