Question about Dryers
LG DLE3733W Electric Dryer - No power at front panel
My LG dryer is a little about 18 months old now, and my wife went to use it this afternoon, and we are getting no power when you press the power button on the front. I verified that the breaker did not trip, and both legs of the 220-240 outlet are working via volt meter. The cord itself looks to be okay, as I get 120 volts at both terminals at the back of the dryer where the cord attaches. I'm assuming there are some other fuses inside the dryer, but before I start tearing it apart blindly, maybe I can get some likely possibilities.
Thanks,
Ted C.
  • TedC Sep 14, 2008
    Thanks. It does appear to be that the thermistor has lived its last. Only getting .5 ohms, when manual shows I should be getting 11.7. Now I have to go find one of these things.
    Thanks again,
    Ted C.
  • SNUGGLECOURT Sep 24, 2008
    I received my LG DLE3777W ELECTRIC DRYER AS A GIFT. AFTER INSTALLING IT ACCORDING TO MANUFACTURER INSTRUCTIONS,
    I TRIED TO TURN IT ON AND THERE IS NOTHING...NO POWER.
  • 706 Answers
Hello Ted C,
Here is a link to the user manual for your dryer ...http://us.lge.com/download/product/file/1000003928/DLE3733_DLG3744owners.pdf
Here is a link for the closest match service manual I could find for you
http://136.166.4.200/contents/Laundry/DLE3777/DLE3777_Service_Manual.pdf
There is a high probability that your door switch interlock is not made and/or the thermal fuse is open. The information contained in the service manual (despite not an exact match) should be close enough to assist in troubleshooting the problem. This information should at least head you in the right direction. Hope this helps you..
Regards
Posted on Sep 13, 2008
  • Rick Gelin
    Rick Gelin Sep 14, 2008
    http://www.mcmelectronics.com/search.asp... they sell components for LG products. I assume that since it is YOUR dryer that you took the time to measure each component and know which part number you need. You should be able to get the part you need from this supplier.. Good Luck
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
My LG dryer is electric, model# DLE3733W The heat doesn't work, all lights on the panel come on according what I set it at. I can then unplug the power supply and plug back up and the heat works until the...
heatman101
Nov 06, 2010 | LG DLE2532W Electric Dryer
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My lg dle3733w dryer is vibrating a lot
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 19, 2009 | LG DLE3733 Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Dryer not drying clothes
I'm guessing it is electric? Do the clothes get very hot? If not, one or both of your elements may be bad. If it does get hot inside after running for 15mins, then perhaps your exhaust piping is clogged up. Can you tell if the output blowing from your dryer is a weak or powerful flow?
Let me know.
Nov 13, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
1,268 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
