Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchenaid dishwasher sucking noise when ON
Our built-in KitchenAid diswasher stopped working. Whenever the ON/OFF switch is ON, it makes a sucking noise.
Before this all started, whenever we selected a cycle, ppressedON and closed the door, a cleaning cycle would begin. Now, when we push the cycle button and press ON, all it makes is a sucking noise (for as long as the ON button is on) and cycles do not start (it does not clean).
Any solutions?
Thanks
Itzhak
    Sergeant:
  • 409 Answers
The sucking noise is the water valve, opening but it doesn't not sound it getting any water in. have the water valve replaced.
do you get any error messages on the display?
Posted on Sep 13, 2008
Kitchenaid diswasher replaced control panel and dishwasher is not working again
Check the door switch, it could be a loose wire or broken door latch switch.
Feb 29, 2012 | KitchenAid KUDS01DJ - Multiple Color...
How long does a normal cycle take on the following Kitchenaid diswasher. KUD102CRWH1 Mine takes hours. Is this normal?
If the normal cycle is taken hours then the water temperature is not correct. If you have inlet hot water connection, then check the water temperature. If using cold water then the thermostat or heater in the dishwasher is faulty.
Look for items 7 and 12 in this diagram.
Oct 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Diswasher control panel not working.
Micro controller to be checked. Refer user guide and contact the service provider.
Jun 01, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
Kud101 diswasher heater element
The dishwasher will heat the water to a temp of aprox 140deg if the heater is not working then the dishwasher will not shut off because it has to heat the water to a point where a thermostat will close during the heating time the dishwasher time stops advancing, also heater is used to heat the air for dry cycle
Sep 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid dishwasher loss of power
Electrical storms can burn out electronic components. Consider investing in whole house surge protection.
If you need assistance in selecting or installing surge protection on main power line, email me buffalonymann@yahoo.com
Jul 30, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
282 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
