Question about Goodman Heating & Cooling
I have a 5ton package unit electric/natural gas. unit is 2yrs old. There is 220 v0lts to the unit. unit will not come on. there was some voltage surge during bad weather at the time unit went down. the 3amp fuse is ok. the little red light does not come on. please help
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This can only be 1--of 2 things, (the easy fix first, transformer or curcuit board is bad) .If you have 220 volts then check for power going into the transformer, (220 vt) and then power going out, (24-28vt) (90% of the time, its the transformer, 10% of the time, its the cuircuit board.! , i
Posted on Sep 13, 2008
Replacing lcd tv 110 volts power supply with 220 v0lts power supply
Hi Anonymous,
In most of the cases the power supply in lcd TVs can handle both 110 and 220 volts. Still if you want to replace it, please check the output voltages of the new supply you want to put. If they are the same you can replace it without any doubt. In case the order of the pins in the connector is not the same, you can cut it away and solder the wires on respective pins. In case you do not get the supply of the same brand, you can use a supply of some other brand with same voltage output.
Good luck.
Aug 08, 2016 | Samsung Televison & Video
My heating unit is coming on and just running not blowing heat at all. what could be wrong?
my first impression is that the filters are too dirty and they caused the high limit to trip. needs serviced.
Jan 31, 2015 | Carrier WEATHERMAKER 48TCEA 4.0 ton Gas...
I have a gas powered kenmore dryer but my new home does not have an gas outlet instead the new home has only an electrical power 220 outlet I want to use my new dryer in my new home. How do I convert from...
You cannot convert a gas dryer to electric. Do you a natural gas line for your furnace? A plumber can easily T into the mainline and run a drop for your dryer. This would be cheaper than buying a new dryer. If you do not have natural gas in your house you will need to buy a new dryer.
Jun 30, 2011 | Dryers
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
Feb 28, 2010 | Weather King 10AJA6001AH Air Conditioner
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
I have an old cozy natural gas heater that cuts off at night
Remove and clean all electreical connections in the unit.
Dec 26, 2009 | Cozy Heating & Cooling
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Heating & Cooling Logo
59 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
