FixYa.com
Tags:
Sony KDF-E55A20 55 in. LCD Television
Power button (by 2 users)
posted by instigator on May 27, 2006
When we turn on the power button it blinks green and then throws a trouble code the power button blinks 6 times red and doesnt power on and continues to blink 6 times skips a second or 2 then blinks 6 times and so on. What is the blinking 6 times mean because supposedly 3 times means the bulb is shot.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 10, 2007
Gentlemen: Thanks for all the advice. I replaced my thermal fuse and my tv is working fine. There is one thing that was not made clear. First the fuse sets in a holder directly under the bulb. there are 2 models for this fuse. the one I had was a metal case being held down by 2 screws--this will be the toughest part. However, if you get the other type fuse which has a small black head like an RTD. then leave the other one in and just slip this one under it. You will have to remove the fan, and the fan housing, then you will see the fuse. I bought 3 of these fuses from parts.com for 30.50 including tax and shipping. So now I have the spare bulb and spare fuses.
Remember, Sony is no help, they will not even sale you a schematic. they want you to send it to the shop. 200 to 400 bucks for a $5.60 fuse.
Thanks guys.
Best Solution
posted on May 27, 2006
Thanks for Trying (70)
bmwrider
Rank:Wiz Wiz
Rating: 84%, 1703 votes
Sorry, I have to say it. If the bulb (LED) is shot it would have to be zero flashes :-) It's my weird sense of humour.
After that I hope you'll forgive me and someone can give you some real help.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 07, 2008
Not Rated (0)
F1forHelp
Rank:Guru Guru
Rating: 87%, 102 votes
Solution #3
posted on Dec 13, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Vance Baldwin Electronics in Lawrenceville GA (near Atlanta) or Ft. Lauderdale FL have these thermal fuses for $4.80. Their number is 1800-432-8542
Solution #4
posted on Dec 07, 2007
Not Rated (0)
circuitcity
Rank:Guru Guru
Rating: 88%, 97 votes
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Can you Help with these Flat Panel Televisions problems?
Coloured vertical lines on...
Hello, I have the coloured... Answer This...
Blinking power light
When I turn on the tv the power... Answer This...
Color Hue tends toward green
I've lost the color balance on... Answer This...
kdfe55a20
The red led light blonks 4... Answer This...
Thermal Fuse
Do you have a picture of this... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
