Hoover H120M Front Load All-in-One Washer / Dryer
Problem for Hoover H120M Front Load All-in-One Washer / Dryer
Smell from tub
By spottydog on May 27, 2006
machine is actually the Hoover AL 120 - a front-loader like the 130. Have run two 95-deg washes without clothes through (2nd with som edettol) bu tsmell persists. Suspect it's bacteria. Shuld I use bleach? With hot water? How?
Comments:
Jun 19, 2006
- I ended up running vinegar through and bleach and soda crystals (all SEPARATELY, note - God knows what would happen if you put them all in together & heated them to 95deg!!). It took a few goes but worked. The key thing, if you don't use v hot washes frequently is to run a service wash once a month (just soap powder at 90+ deg, no actual laundry). If there is a smell you will have to use one or more of the above remedies. An important tip (to avoid bacteria build-up) - keep the door open when not in use. (If you have small pets, this will mean checking inside before bunging a load of laundry in & shutting the door!)
Hoover's own website was v useful (sorry can't remember the url)
Best Solution
posted on May 28, 2006
Very Helpful)
dovi
Rank: Guru
Rating: 88%, 2496 votes
Does it the first time you have this bad smell and for how long do you use this machine in its cuurent location ?
Try to run an empty machine cycle with a quart of vinegar to clean the tub and pump.
Let me know if it solve your problem ?
Good luck !
Was this helpful?
Yes
No
Popular Solutions for Hoover H120M Front Load
Questions and Unsolved Problems for Hoover H120M Front Load
Do you recommend Hoover H120M Front Load All-in-One Washer / Dryer?
Answer
Answer
Hi I cant seem to work the tumble dyer part of my machine how do you operate this
Answer
Door closes but lock light doesn't come on. It won't take in water or spin but if I start another... (More)
Answer
my washing machine doesnt spin properly clothes come out soaking wet the dranage is not clogged... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover H120M Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
