Question about Frigidaire Dishwashers
Water keeps running into dishwasher
Walked into my kitchen this morning to find a lake. The dishwasher was leaking water from the door. I turned off the valve under the sink and cleaned the message. The washer was able to drain the water that remained in the bottom and we turned it on and all seemed fine. The water started again and I turned the knob to off and opened the door. The water continued to enter the machine even in the off position. The only way to stop the water was turning off the valve. If I turn the valve back on with the washer off, the water does not enter, but as soon as we turn on the washer on we can't make the water stop coming in until shutting off the valve
  • kelle6120 Sep 14, 2008
    Thanks techgirl. It's a Fridigaire Ultra Quiet Plus. The model number is FDB65RAC0; serial number TH13957079.
  • tll237756 Jan 03, 2009
    mine is doing the exact same thing. Frigidaire FDB510LCB0 Serial # TH32816857. Where is the part located in the dishwasher.
    The water will run in we'll do a load of dishes and we'll have to turn valve off as soon as the washing cycle is done because the water keeps running in even if we unplug the dishwasher.
AEG Electrolux Favorit 44450
Posted on Dec 29, 2014
  • 3 Answers
It looks like your inlet water valve is stuck after it powers on which means you have to replace it. If you can provide me a model and serial number of the dishwasher, I can provide you with the correct part number and a breakdown diagram. You can find the model number on the door frame of the dishwasher.
Post it back
techgirl26
Posted on Sep 13, 2008
  • Steven Carter
    Steven Carter Feb 16, 2014
    I have the same problem Hotpoint Americana model ADW1100N10WW
Fisher and Paykel DW920 dishwasher pump wont stop
This means the flood circuit is triggered. There is a leak in the dishwasher causing water to collect in the motor chamber. The leak is usually through the door seals or broken hose. Disconnect mains electric and water connections and pull dishwasher out from under kitchen bench. Tilt it from side to side to get the water out from under the base. Wait a little for water to dry up. Reconnect mains power and turn on to see if pump stops running. As mentioned source of leak needs to be fixed.
Mar 15, 2013 | Fisher and Paykel Dishwashers
LG dishwasher leaking out the bottom of the door. It's that gasket that runs along the inside bottom of the door. How do you keep it in place? It keeps pushing in and then floods my kitchen.
My dishwasher was doing the same thing, but it was because of a clogged vent. The minerals in the water built up to a point that it was totally blocked and since it couldnt vent, the water ran down the inside of the door and leaked out the bottom. I just popped the vent cover off of the inside of the door and cleaned it out and it stopped leaking.
Nov 16, 2010 | LG LDF9810ST Built-in Dishwasher
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Dishwasher started leaking suds and water out of the bottom
Please reply with the manufacturer and model number of the dishwasher.
I doubt that you have done any lasting damage to your dishwasher. Recommend that you empty the DW, start the dishwasher with no detergent added. Select a quick cycle if it is available, but more than a rinse. As soon as the water fills and the wash cycle begins, open the dishwasher and add at at least 1 cup of White Vinegar and close the door.
Keep an eye on the unit to make sure the suds don't overwhelm you again. If it does, go to a store that rents carpet cleaners and by just the de-foamer bottle. Add one table spoon or so. The suds should get knocked down.
After problem is resolved: Recommend you switch to a brand name Washing powder like Electrosol or Cascade. Avoid gel or the tablets for all dishwashers.
Good Luck!
Apr 01, 2009 | Dishwashers
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Westinghouse 906 leaks from front door
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Water won't stop entering the dishwasher
SOUNDS LIKE YOUR WATER INLET VALVE HAS FAILED,,REMOVE BOTTOM PANEL AND REPLACE,MIKE
Sep 13, 2008 | Frigidaire 24 in. FDBB840DC Stainless...
Water seeping in dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
1,195 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
