Question about NEC ND-6500A DVD±RW Dual Layer Burner
Cannot read dvds
NEC ND 6500A DVD burner . this is the 2nd drive i have had that develops fault will only read cds
  • 1 more comment
  • Marco De Sanctis Nov 28, 2007
    I have a Nec ND-6500A with firmware version 203E on Dell Inspiron 6000 notebook. I have problems with all DVD - Rom that i try to read. The reader seems reading more times, but he fails.Thank you in advance for Help
  • Anonymous Mar 07, 2008
    code 41 under device manager
  • Anonymous Mar 19, 2014
    dont read unwrit
    en cds
Cleaning the DVD drive helped my problem of Not reading or writing DVD-R
Posted on Apr 03, 2008
Sounds like your dvd laser has failed if it reads other media as there are normaly 2 lasers one for reading cds and one for dvds try using a cleaning disc to clean the lenses
Posted on May 29, 2006
Problem with NEC DVD
Cd's use a different file structure that dvd's. Dvd's use udf and cd's use cdfs. Try cleaning the drive with a cleaning cd and downloading the latest drivers for the drive from the NEC website for the easiest fix.
Aug 30, 2009 | NEC ND-3550A-KIT DVD±RW Burner
My dvd drive will not play original dvds or + dvds but will play dvds and cds burn on - dvds and cds
Hello there:
you might need to check to see the format of the dvd that you are trying to play ie dvdr vice dvd some devices will not play them if the format of the cd is wrong
Aug 06, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Apr 20, 2009 | NEC ND-2500A DVD±RW Burner
Nec dvd rwnd 3500ag
my burner plays dvds but wont play cds
Mar 01, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
I have problem with my AVERATEC COmputer
This is a common issue with NEC DVD burners, assuming that your NEC DVD burner cannot read and write DVDs anymore. I had a similar issue with my NEC DVD burner, which couldn't read and write CDs, but DVDs successfully. This is usually due to wear and tear of constant usage of the drive itself and sometimes mechanisms inside the DVD burner cease to work. While Windows Troubleshooting, uninstalling and re-installing the drive are suggestable, I am afraid the only option is a complete DVD burner replacement.
Feb 22, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
NEC ND-6500A Cant burn DVD-R
I figured out what was causing the problem with my NEC 6500A on my Dell laptop: The Sony Picture Motion Browser software that I was using to burn DVD's is only compatible up to Service Pack 2 of Windows XP. The day after I installed Service Pack 3, the software stopped burning DVD's. So I uninstalled Service Pack 3, rebooted, unistalled the Sony PMB software, rebooted and re-installed the Sony PMB software and I can now burn DVD's again. So check whether the software you're burning your DVD's with is compatible with whatever version of your operating system you're operating with. Hope this helps someone else!
Dec 16, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6500A DVD±RW DON'T READ CD
I have encountered this problem numerous times and, while I'm not sure of the exact cause, the remedy that works 90% of the time for me is to create a 1:1 solution of isopropyl alcohol & distilled water and to GENTLY brush the laser with a cotton swab tipped with this solution.  Afterwards, use the other side of the swab to completely dry off the laser, ensuring that absolutely no cotton fibers are left behind.  Good luck!
Oct 30, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC 6500A DVD Rw
I used to have a DVD/CDRW driver on my Sony Vaio and I had to replace it twice it died on me and I had to buy a new one every time the truth is that many things can go wrong for such small device so try this go to http://drivers.softpedia.com/get/FIRMWARE/Nec/Nec-ND-6500A-firmware-424.shtml Download the firmware, if after that it still wont work your chances are that you have to buy a new one.
Aug 21, 2007 | NEC ND-6650A DVD RW Dual Layer Burner
CD/DVD won't eject, won't play, Device Manager doesn't recognize.
If it's only 8 months old, then you have atleast 4 months left on your warranty. The problem will either be the ide controller channel or the dvd drive and firmware has faulted, the same fault probably happens when you have put a dvd in and it wont read or eject. Return to the place of purchase, where the drive should be replaced or the notebook exchanged.
Aug 11, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC nd 6500a
Hi, I think that it's a firmware issue. If the unit is till covered by warranty, you may have to bring it back for replacement. When doing so, it may be to your advantage to bring the PC while it is still attached and blank CDs and DVDs just to demonstrate the particular failure and likewise to be able to test if and when it would be replaced. If for some reason, you would want to try DIY, please look over these sites that you may have an idea. http://www.cdrinfo.com/forum/tm.asp?m=132275&mpage=1𠓝 http://liggydee.cdfreaks.com/page/6500/ Hope this be of some help and pls post again how things turn up. Good luck and kind regards.
Aug 04, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6500A DVD±RW Dual Layer Burner Logo
181 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
