Question about Frigidaire 24 in. FDBB840DC Stainless Steel Built-in Dishwasher
Water won't stop entering the dishwasher
Went into my kitchen this morning and found a lake. The dishwasher seems to be running through the cycles, but the water never seems to stop pouring in, even if I turn the knob to off. If I turn the water valve off under the sink, then turn it back on the water doesn't enter the dishwasher. If I turn the dishwasher on again the water doesn't stop.
  • kelle6120 Sep 14, 2008
    Thanks!! Will try to replace and post back.
    Genius:
  • 1,122 Answers
SOUNDS LIKE YOUR WATER INLET VALVE HAS FAILED,,REMOVE BOTTOM PANEL AND REPLACE,MIKE
Posted on Sep 13, 2008
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Tip
Dishwasher Water Temperatures
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
on Sep 08, 2015 | Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Water refilling after dishwasher is cycled off
Leave the D/W door open and make sure the water is not coming from the water inlet .
It may be oozing up from the bottom when you run water in the kitchen sink.
Does your dishwasher vent through a counter top Y siphon. It could be clogged causing water to re-enter the D/W.
Feb 10, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Water keeps running into dishwasher
It looks like your inlet water valve is stuck after it powers on which means you have to replace it. If you can provide me a model and serial number of the dishwasher, I can provide you with the correct part number and a breakdown diagram. You can find the model number on the door frame of the dishwasher.
Post it back
techgirl26
Sep 13, 2008 | Frigidaire Dishwashers
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
If this is a blinking "clean light", this is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there are some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
Feb 16, 2008 | Dishwashers
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Frigidaire 24 in. FDBB840DC Stainless Steel Built-in Dishwasher Logo
186 people viewed this question
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
