Question about HP Computers & Internet
MY COMPUTER STOPS RESPONDING AFTER A FEW MINUTES OF USE
I CAN SHUT IT DOWN AND IT WILL WORK FOR AWHILE THEN IT STARTS THE SAME THING
Check you power supply. You may have to upgrade if a lot of accessories/components have been added.
Posted on Sep 13, 2008
My 99 mercury cougar is a 2.5 v6 (Problem) it sputters all the dash lights go off and the power steering dosen't work and the motor dies after it runs for a few minutes. the car will start after it sits...
Sounds like a fuel problem. The electronics shutting down are the result of the dying power. Start by changing the fuel filter. If that doesn't work; I'd look into the fuel pump.
Dec 18, 2010 | 1999 Mercury Mystique
My a/c unit will start but after a few minutes it will make a noise and stop. Then if I wait awhile and turn it on again it does the same thing.
It may have a low charge. A/C units have a safety that's called a low pressure control. When the unit runs the compressor will **** down the gas pressure and cause it to shut off. After time the system will balance out and the pressure on the low side will go back up. This will cause the compressor to come back on. The other thing that comes to mind is the compressor motor might be shutting off on overload and turning back on after it cools.These are first things I would look at. Always make sure your air filter is clean.
Apr 19, 2010 | Coleman Mach 15 Air Conditioner
Software shuts down. says not responding. has
hi,, it can be an problem with your RAM,,mostly,, or else can be your motherboard / processor, but first you have to try replacing your RAM..with other ones
Sep 27, 2009 | Sony Vegas Movie Studio for PC
Vacuum shuts down after 5-10 min of use
It may have a problem of overheating. If you havn't cleaned out the thing that holds all the dirt and dust, you may want to consider doing that. There might be a thermostat in it that shuts down whenever it thinks it's to hot.
Aug 20, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Car shuts off at red lights
sounds like a lose ground wire
Dec 15, 2008 | 2002 Oldsmobile Alero
Dryer starts then shuts off
it seem like your motor could be faulty (overheating) causing the thermal overload to open, stopping the motor after awhile it will cool down and the thermal will reset, if this the case the bearings or the windings could be faulty
Dec 13, 2008 | Dryers
The power shuts off after a few minutes
There could be several factors. Are there any indication or failure lights/codes prior to the unit shutting down? You didn't mention where the unit is located. Does it initially start to read the disc then shut down or is there no activity at all? Please respond with some additional info & we'll go from there.
Feb 21, 2008 | Televison & Video
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
